Page 8 of 12 FirstFirst 123456789101112 LastLast
Results 71 to 80 of 112
Thread: 2000 Pontiac Trans Am carputer install
  1. #71
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Hey, that looks like my car!
  2. #72
    Oct 2005
    Hou. TX
    Yep, have you seen any other TA's or firebirds with similar screens?
  3. #73
    Mar 2004
    Florence Yall, BFKY
    Nope. Nothing that really looks as good as Snootch's.
  4. #74
    Oct 2005
    Hou. TX
    Quote Originally Posted by Curiosity
    I prefer yours because it is more in line with what I plan to do.
    How is the visabilty with the screen mounted at that angle?
    Any glare problems?
    I have T-tops, think I'll need to add a hood or anything?
    I think the TA has the radio area angled slightly towards the driver, does that screen look good from the passengers side also?
  5. #75
    Jul 2004
    Santa Barbara, CA
    i've got a similar setup in my camaro, but my screen is not hardmounted yet. I'm not sure if i want to for theft reasons but when i just set it in front of the HVAC controls the glare can be pretty bad even w/ the t-tops and tinted windows rolled up. I'm thinking i'm going to end up mounting it on an adjustable swing arm or osmething, not fully sure though, right now i'm broke as a joke so i've got a little while to plan and save for a full stereo system overhaul.
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
  6. #76
    Oct 2005
    Hou. TX
    Quote Originally Posted by jrtf83
    i've got a similar setup in my camaro, but my screen is not hardmounted yet. I'm not sure if i want to for theft reasons.
    Wouldn't molding it in be a good way to PREVENT theft? When it's off it should look like some blank delete panel or something.
    I always thought the monitor on a stalk was a dead give away that it wants to be stolen.
    As far as glare, I usually drive at night, so it shouldn't be a problem most of the time. I think I'm still going to get the 7" lilliput.
    Hey Snootch, hows the glare on your larger monitor? Does the hood help at all?
  7. #77
    Oct 2005
    Hou. TX
    Here's a nice one similar to Snootchs from a member named Firebird.
  8. #78
    Jul 2004
    Santa Barbara, CA
    ya at night its beautiful. Also, if you guys are running road runner, there are a few add on programs that control the gamma correction depending on the time of day, making it brighter in the day and darker at night, kinda cool. My thinking was the have it removable like a faceplate from the stalk.
    -Ross
    02 Camaro SS
    Tot: $983
    Buying stereo!
  9. #79
    Mar 2004
    Florence Yall, BFKY
    Mine has hardware dimming, so the blacks look blacker at night. The angle is better for the driver, but still very readable by the passenger. Sometimes they have to lean in just a little, but I don't mind that. The biggest problem I have is if she's wearing white and the sun is shining from the front or the T-tops. The reflection makes it impossible to see anything. The hood wouldn't help there, but it's not going to happen as often as direct sunlight. Also, I have tint and T-top shades. I think the dark leather seats help a lot when you don't have a passenger too - after thinking about the white shirt reflection.
  10. #80
    Oct 2005
    Hou. TX
    Here is a possible idea for those wanting to run a 8" or 10". Make a pod to hold the A/C controls above the air vents. Kind of like the pods that hold guages. I could get an extra dash pad and have the pod overlap the vents some. Then cut out the vents that the pods covers to allow the cables and wires to go into the dash area. The whole pod could be attached to a flat metal mount that screws down under the dash pad so that the nice dash area above the vent won't be damaged in any way.
    I've also checked and this location does not obstruct the view at all.
    If any of you guys had not already bought your screen or relocated the controls to the glovebox and were starting out from scratch, like me, does this seem like it would work?
  1. pontiac sunfire 2000
    By Phantm in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2005, 10:00 PM
  2. 2000 Sunfire Install
    By CavityCr33p in forum Worklogs
    Last Post: 04-13-2005, 12:33 PM
  3. 97 Acura Cl carputer install
    By elserpiente in forum Show off your project
    Last Post: 04-11-2005, 05:48 PM
  4. Replies: 1
    Last Post: 02-03-2004, 02:02 AM
  5. Ready to install Carputer
    By petera in forum Power Supplies
    Last Post: 01-05-2004, 12:52 PM
