Page 1 of 12 1234567891011 ... LastLast
Results 1 to 10 of 112
Thread: 2000 Pontiac Trans Am carputer install
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    2000 Pontiac Trans Am carputer install (56K=choke)
    As i'm starting to get my install together, I figured i'd document it here pic by pic. I am currently saving money so that next month, I can just buy everything I need at one time. I have a final parts list, and here it is:
    I'm going to add an Audigy USB sound card, and a GPS mouse after this is installed as I save up some more $$.
    I have started some fabrication work, and here are the pics:
    First, a pic of my car:
    Then, the stock dash:
    I relocated my A/C controls to the glove box:
    Then, moved some stock electronics (relays, etc.) to get as much space in the dash as possible: (edit: I moved that small black box tucked in the left hand side to under the driver's dash)
    I bought two 12"x12" (1/8" thick) ABS sheets from McMaster-Carr for $17.00, and trimmed one to fit the dash opening:
    More pics to come as I work some more on it.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Constant Bitrate ltrain1007's Avatar
    Jan 2005
    NJ
    so fun, congrats on the start of the project
    Go on and do it, do it, Do it 'til you're satisfied,
    Whatever it is, do it, Do it 'til you're satisfied.
    CarPc progress |OOOOXCOOOO| 57%
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Me thinks you need to work on your parking skills. So you're only putting an 8" in there? Looks like there's room for more.
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by Curiosity
    I might be able to do a 10.5" LCD, but that would require serious modification of the dash, and I kinda want to be able to sell the car in stock form if needed. Also, I forgot to add, that with the dash work, i'm using all ABS, utilizing the solvent/ABS goop brought up by CoachReed in the Fabrication area. So far, it,s coming out well.
    WORKLOG
    Webpage
    Sep 2003
    Tampa, Florida
    Got a little more work done today, I'm working on the stock trim bezel, and adding a small hood on it to help cut down on glare. Here's a pic of the stock bezel with the crossbar between the AC controls and the radio removed and filled in:
    then I glued on the top and side parts of the hood using the ABS goo:
    I used three layers of ABS on the top portion of the hood, and two layers thick on the sides:
    As soon as it dries, i'm going to sand it into shape. I think I might be able to get some more done with it tomorrow if the ABS is thoroughly dried.
    WORKLOG
    Webpage
    Variable Bitrate Fraychild's Avatar
    Jan 2005
    Somewhere I Belong ~
    You're definitely on the right track man... keep us posted...
    Is there anywhere else one can get ABS plastic sheets for cheaper??
    VER. 3.0- Check out below:
    車コンピュータ 3.0
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Very nice Trans Am... Good luck!
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by Fraychild
    I dunno, you would probably have to do some hunting locally. I just bought this stuff 'cause I didn't feel like hunting for it to save $5 or so.
    WORKLOG
    Webpage
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by RS3RS
    Thanks for the compliment- Spent way too much money getting it to look/drive like it does.
    WORKLOG
    Webpage
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    Is that a Rockford Symmetry I see ? Thats a flashback to the past that I've been wanting for awhile and the install looks like it will be pretty cool when finished, keep us posted
  1. pontiac sunfire 2000
    By Phantm in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2005, 10:00 PM
  2. 2000 Sunfire Install
    By CavityCr33p in forum Worklogs
    Last Post: 04-13-2005, 12:33 PM
  3. 97 Acura Cl carputer install
    By elserpiente in forum Show off your project
    Last Post: 04-11-2005, 05:48 PM
  4. Replies: 1
    Last Post: 02-03-2004, 02:02 AM
  5. Ready to install Carputer
    By petera in forum Power Supplies
    Last Post: 01-05-2004, 12:52 PM
