Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: 01 Metro LSI 4 door
  1. #11
    Low Bitrate c4shm0ney's Avatar
    Jul 2004
    Indianapolis
    I am reconsidering the system cooling idea as it has been stable today which is equally as warm as yesterday. The wireless tempeture probe shows the temp inside the case at a peak of 104.5 today with the system operating stable.
    I completed a mount for the Datalux TFT today. The mounting bracket is made of steel with an aliminum tube connecting each wing of the bracket tied together with a piece of allthread and wingunts. The gooseneck is made of a 3/4" copper pipe a 1/2inch pipe mounting bracket and a 3/4inch 'pipe sealer' for lack of a better word to describe it. The goose neck is mounted into the left tap that holds the passenger seat with a locking nut/washer and about 2" of thread into the tap. I will be painting the mounting bracket and covering the copper with pipe insulation for astehtics and to manage the cables.
    The mount as you might expect causes a bit of vibration on the display however I suspect there is little that I can do as the vibration is coming from the car/road and not because a design flaw.
    The mount is very functional I can tilt the screen up-down left-right, push to be flush with console for passengers or push down to the floor.
    01 Metro LSI
    79hp 41MPG Highway
    Check my progress
    http://www.mp3car.com/vbulletin/worklogs/51295-01-metro-lsi-4-door.html
  2. #12
    Jul 2004
    Indianapolis
    01 Metro LSI
    79hp 41MPG Highway
    Check my progress
    http://www.mp3car.com/vbulletin/showthread.php?t=51295
  3. #13
    Jul 2004
    Indianapolis
    Talking
    I am dissapointed with my Datalux during the daytime. The glare is unbearable I would almost rate this unuseable in day light. I'm currently working to find a solution to the glare problem.
    01 Metro LSI
    79hp 41MPG Highway
    Check my progress
  4. #14
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by c4shm0ney
    And so another one joins the LCD backlight upgrade mission...
  5. #15
    Jul 2004
    Indianapolis
    Post
    I am thinking about testing out a fine nylon mesh screen over the display from what I understand it should cancel out most of the glare.
    I suspect that the mesh would make using the touch screen almost impossible however if it worked it would be a removeable overlay that would come off at night.
    If all else fails I am seriously considering putting a higher power inverter and tubes up in this mofo.
    ref: http://www.displaymate.com/glare.html
    01 Metro LSI
    79hp 41MPG Highway
    Check my progress
  6. #16
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Did someone say LCD backlight upgrade?
    Hey hey hey, I'm getting a crazy idea!
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
  7. #17
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Whoa, a carputer in a Geo Metro... And I thought I'd seen it all!
    I used to have one of those babies, all 3 cylinders worth of raw hampster-power!
    All kidding aside though, looks like the install is going well.
  8. #18
    Jul 2004
    Indianapolis
    The last Metro is actually a Chevrolet product and it's 4 cylinder's thank you very much.
    Yuirry I checked out your install, I wouldn't call it ghetto exactly, dangerous and scary would fit better.
    What did you have in mind regarding the tft upgrade project?
    01 Metro LSI
    79hp 41MPG Highway
    Check my progress
  9. #19
    Jun 2004
    Seattle
    I have several LCD screens of 10.1" and 12.1" sizes from my previous setup. All of them have working backlight bulbs and inverters that work off a 12V source. I'm going to try and fit an extra bulb into my tablet and see if it makes the screen any brighter during daylight. If I succeed, other people can do it. These LCD's are around $40 with an inverter shipped from eBay.
  10. #20
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    it's all cool, I'm just a southside balla on a budget.
    now that is pure comedy!
    as for the cooling issues of the case, i would consider putting another fan on the opp. side of the fan that you installed on the left side. this would increase the airflow over the heatsinks
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Door handle
    By i3igmind in forum Car Audio
    Last Post: 05-23-2005, 02:19 AM
  2. Garage door torsion spring
    By MatrixPC in forum Off Topic
    Last Post: 02-11-2005, 06:54 PM
  3. 01 Metro + laptop install = most getto carputer
    By cash_Money in forum Show off your project
    Last Post: 12-09-2004, 10:03 AM
  4. AutoTap ODB-2 cable...
    By coleman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-29-2004, 12:13 AM
  5. Replace door inserts?
    By SuperMatty in forum Off Topic
    Last Post: 12-02-2002, 12:54 AM
