Results 1 to 10 of 10
Thread: 1995 Saturn SC2
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    1995 Saturn SC2
    My crappy carputer. Its a M6000 powered by a OPUS90w that boots from a 13 gig 3.5" hdd and outputs a composite signal to my widescreen lcd. Nothing special, YET!
    widescreen lcd
    ...again....
    Your typical 10$ Walmart tool box velcro'd into a messy trunk. (carputer inside)
    a $2 electrical conduit box modified with switches that control power to the lcd(bottom) and the opus remote line (top, obviously)
    I am finally back home so I again have a driveway to work in. yay yay!!!!!!!!!!1111!!!11!!!1!!one!!!1111
    Constant Bitrate blasterguy128's Avatar
    Feb 2005
    Fort Lauderdale, FL
    Hey if it works for you, enjoy! Could be a lot worse.
    Only thing is that screen. It is begging to be stolen. Good Luck
    That tool box blends right in, if there wasn't a fan grille I would have never suspected it to be the comp.
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    case= 1/10 scale model of my car (04 Saturn Ion QC)
    soundcard= soundblaster mp3+
    GPS= Holux gm-210
    Jun 2003
    Fairfax, VA
    the screen has a quick release on it and gets stowed under the seat out of view. I am thinking of bulding some sort of enclosure around it to give it the apperance of being built into the dash, kinda like the Toyota Prius. I hope that would be a theft and police deterant.
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Yes, yet another Saturn install
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Well, the screen is pretty much screaming to be stolen, but as long as you put it away when you park.
    I like the idea of using an "electrical conduit box" for switchs, may have to look into something like that myself, as I've been toying with where I can put switchs without cutting anything up...
    Jun 2003
    Fairfax, VA
    Ok, where should the LCD go? I am ready to perm mount it in, but I just cannot deceide how or where to put it.
    Low Bitrate homchz's Avatar
    Jun 2005
    Lee, NH
    I have no input onthe screen, though haveing owned and 95 saturn I know there is not a lot of room for a monitor in the cabin.
    But, I have to tell you that tool box set up is great. Disguising the computer as an every day item, that is innovative.
    Nice job.
    Joshua Jones - New Folk Singer Songwriter & Web Site Design (Yep, that's what it says)
    Plans:
    Micro ATX MB, 1.6 Ghz AMD AthlonXP-M, 512MB RAM, 20G 2.5" HD, Thinline DVD, 10" Touchscreen Display (Front)
    Web Log
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Suggestion:
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    i think i mentioned that same place in another thread in fabrication... its seems to be best!
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
    Jun 2003
    Fairfax, VA
    Ok, so the carputer was out for the whole Fall semester, and im ready to get it back in.
    The first problem I remember having was that after about 20 or so startups from hibernation, the carputer would freeze about 5 minutes after startup. This would require me to stop the car, unhook the main power cable from the carputer and reconnect it. This is a pain in the arse.
    So the new carputer will have a built in relay that will be placed between the main power feed and the opus. With the coil unloaded, the relay will allow current through to the opus. A momentary switch will then be placed between a 12volt source and the coil on the relay.
    When the carputer freezes, all I need to do is hold the momentary switch for about 10 seconds to remove the power from the opus to allow a fresh reboot.
  1. Saturn Ion vs Mazda 3 ?
    By jon-paul in forum Newbie
    Last Post: 04-09-2005, 05:46 AM
  2. 2004 Saturn Ion Sedan
    By elmo_eats_rust in forum Show off your project
    Last Post: 02-05-2005, 03:34 PM
  3. connecting a powersupply to saturn SL2
    By BlinderBomber in forum Newbie
    Last Post: 03-22-2004, 09:19 AM
  4. Mp3 Sc2
    By mars_volta in forum Show off your project
    Last Post: 03-14-2004, 02:08 PM
  5. Saturn VS. Toyota
    By lstrunk in forum Off Topic
    Last Post: 06-27-2002, 03:41 PM
