Results 11 to 20 of 22
Thread: VanPimpinLI 90 Chevy Van Worklog
  1. #11
    Jul 2004
    [lostreception] Why don't you see if you can find another console piece at the junkyard? It might be cheaper.
  2. #12
    Raw Wave lostreception's Avatar
    NY
    cheaper in terms of what the piece im going to start the fabrication on now is a junkyard piece so ive ripped it apart quite alot just dont really care what happens to it. so far so good ive never used bondo b4 so it should be interesting. i need to find some time to take care of it.
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  3. #13
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Vans are awesome, carputers go well in them
  4. #14
    NY
    ok so far so good looks like ive got this biostar problem under control.
    i got the svideo output cable and seems it was outputting to that video source instead of vga
    be sure to see this post as well as that whole thread even. [especially if you have a biostar]
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  5. #15
    NY
    wow 2 months and im still uninstalled someone yell @ me
    UPDATE sorta:
    hopefully ill be able to find some time to continue snaking wires and running the rest of the wires to the front. i since got a rearview cam off ebay from the seller cooleyes it seems to work well for my needs bench testing it but i still need to see how it will go installed in the van.
    I also think im going to install the battery isolator but im totaly sure i need it
    without my amp hooked up everything works great i just think that when the amp draws current i may run low on the line side. i figure better safe than sorry but im sure if im going overkill i already have 2 batteries ?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  6. #16
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    yells loudly at lost for taking to much time! by the way couldd u stop by my worklog and do the same for me! I'm de-installed for 3 months now lol
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
  7. #17
    Low Bitrate 99bravada's Avatar
    Dec 2003
    Fort Lauderdale
    Vannin'
    Hey man, I got a rear view cam for my 1977 Chevy G20 shorty and am about to install it in the keyhole in the passenger-side rear door along with a power lock for the rear door (since keyhole will disappear). The camera is a little bigger than the keyhole, so I'll have to bore it out a bit, but it's a perfect place for the cam. In my 1993 Chevy G20 I put a 12.1" touchscreen LCD in the same plastic shell over the engine cover. I cut out a large portion of the shell with a dremel but it fits perfectly... If you can ever get your hands on a 12.1 screen it looks incredibly pimp in the dash for a '78-96 Chevy Van. A decent sized mini-itx computer can fit in the dash behind where the stock radio was, so when you take it to a mechanic, all you have to do is remove the shell and disconnect power/video cables.
    Current:
    2011 Black Jeep Wrangler Unlimited Rubicon | 20" KMC Rockstars | 35" Nitto Mud Grapplers | Rugged Ridge XHD Front Bumper | Kicker KX350.4 amp
  8. #18
    NY
    I am going to be puttin an lcd there 10.4 most likely all the 12.1 i found were datalux and used
    yea that keyhole is perfect i agree that where my cam will be going as well
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  9. #19
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    Lostreception, I intend to get a van just like yours soon, and I have a similar idea on where to put my monitor.
    I spoke with a car audio installation shop about putting the monitor on the console above the doghouse, and they said they'll have to cut a hole in the shape of the monitor to make it flush, which also means taking out the door. Do you know if a 17 inch monitor would fit there?
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
  10. #20
    NY
    probably not a 10.4 vertically fits perfect for me but if u wwant big you can always do 17 theres tons of room just might need some more modding
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  1. OBD in 1995 Chevy G20 van.
    By VanMan69 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-20-2005, 02:15 PM
  2. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
