Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 2003 100th anniversary Harley davidson F-150
  1. #11
    Constant Bitrate BADDERICK's Avatar
    Jun 2005
    Las Vegas
    Quote Originally Posted by mchipser
    i am deployed to iraq and was thinking of doing kinda the same thing to my truck, when i get home. but i was thnking maybe replaceing the radio with a lcd there. and put the pc under the passenger seat. but then i am wonderign if i do that am i gonna have to replace the speakers with "pc speakers" and if so how hard will that be? anyway tell me how it goes with you
    Myk3
    I actualy did go with the touch screen in the dash. I haven't been updating pictures to much. I bought another radio bezel and cut it and streched it to fit my 10.4" touch screen. I did it all with abs so it shouldn't ever crack. I'll attach a picture of where I am with it so far. It is a very slow process, the abs takes days to dry in thick areas. And I just started a new job so I haven't had near as much time to spend on this. When you start out to do it you think oh, this will be nothing, but then it goes on forever...LoL.
    As far as the speakers go. No, You can use your car speakers. You just go from the output of your computer into the factory amp in your truck. There is a little more involved but thats basicly it.
    I am still working on The AC controls. I would like to make it run off the computer too.
    2003 100th harley F-150
    PCChips C3 VIA/eden, M1 ATX smart car.
    Here is my project so far: My 100TH Harley-Puter
    Ride safe
    Buy my stuff: Stuff
  2. #12
    Jun 2005
    Las Vegas
    First I cut it.
    Ride safe
    Buy my stuff: Stuff
  3. #13
    Jun 2005
    Las Vegas
    Then I heated it and spread it out.
    Ride safe
    Buy my stuff: Stuff
  4. #14
    Jun 2005
    Las Vegas
    Then I gooped in some braces to support that, Once that was dry I abs gooped in my LCD bezel.
    Ride safe
    Buy my stuff: Stuff
  5. #15
    Jun 2005
    Las Vegas
    Then I ordered a sheet of 1/8" abs and cut out the rough shape of the top and bottom that I wanted. I sanded, and heated them until they fit in perfectly where I wanted them. I clamped them and gooped them in from the back, waited for that to dry and unclamped them and and started layering thin coats on the top. sanding them in between coats seems to help it to dry, You have to break the seal on the surface for it to dry inside quicker.
    One more thing I should mention. The replacment bezel was only painted on the outside. Before I glued anything to the outside I sanded it to bare plastic.
  1. 2003 VW GTI 1.8T 20th Anniversary
    By askthefool in forum Show off your project
    Last Post: 10-26-2004, 09:21 AM
