Pictures
This is a complete revision of my Car computer.. the original design has a commell LV670 board behind the dash and i decided to go the Laptop route.
This new system is running the following hardware and is 100% funcitonal with the exception of the shutdowncontroller auto powering the on/off of the laptop.
Equipment:
Ibm T30 laptop with 40gb hdd
Xenarc 700TSV mounted in Double din sized dash
Creative Sound Blaster Audigy Zs Notebook
XMPCR with toslink
Holux Gm-210 usb gps
2x Belkin Tetra hubs (1 in the front and 1 in rear)
1 playstation 2 mini keyboard
Belkin usb bluetooth
Jeff Muchas shutdown controller
Shuttle Express a MUST HAVE!
X10 Remote
Buffalo USB 802.11g wireless usb
Sound:
Earthquake PHD3 amplifier for Pioneer TSW5000SPL subs in sealed enclosure
Alpine MRV-F540 amplifier for 4 Morel 4 inch mid bass speakers and 4 Pioneer ODR series Tweaters
Power:
2x Hawker Odyssey PC1700 batteries 1 for normal use / 1 for extended cpu usage when car is off
Dual rectifier CS144 275 amp alternator
Software:
Iguidance 2.0
Mediaengine
Windows XP
-Jack
2006 Chrysler 300C AWD
Samsung Galaxy Tab In dash
Pictures
-Jack
More pictures
Notice the reverse camera mounted in my taillight! Great camera with wide angle viewing... ebay special..
-Jack
Timing...
To eliminate pops form the amplifiers i ended up gettin a tiem delay relay that will delay power on for 45 seconds. This helped greatly the computer is just about ready to play when they kick on.
The shutdown controller is set up to turn all power off after 1 minute from powerdown.
Powerdown should be quick since i disabled the swap file in xp due to the 1gig of ram the laptop has. IT has helped greatly.
-Jack
How did you install that backup-cam? You cut a hole in your backup light?
The A8 has a release lock there, he probably just removed it, and installed it there.Originally Posted by Hark
Man, you have one of my dreamcars. Will you be coming to the meet? I'd like to check it out... Nice job done... Props!
Got any pics of the T30 mounted? Did you change the bulbs that light up the footwells to red, or did it come that way?
Originally Posted by BoyNextDoor
Actually i drilled a 1 inch hole in the driver side taillight. The trunk lock is actually on the pass side. I wanted to make it even.
Give me details on the gtg id love to go if i can make it.
-Jack
Ill get more pics this weekend. However the red color is from a set of 4 6 inch neon tubes in each footwell front and back.Originally Posted by Hark
-Jack
