Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Phase 2 Peugeot 306 Install
  1. #21
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    I am mounting mine like that.
    Make sure you dont have a heavy heatsink and possibly mount the fan to the case not the heatsink (but keep it close) and maybe provide some bracing to the mobo (not the case) as the mobo will move and if theheatsink it braced to the case it willr ip off.
    I would not lay a mobo flat as the vertical motions will cause the board to flex in its weakest direction.
    One question though.....could you have made that enclosure smaller and can you post the dimensions as I am planning mine.
    Also, i see you plan on using an M1-ATX - i wouldnt for a 1.4duron. I would go for an Opus 150W (120W min) or possibly the new M2-ATX
  2. #22
    Jul 2005
    Portsmouth, UK
    Quote Originally Posted by Scouse Monkey
    Doubt I can afford a Opus, can't afford the M1 let alone the Opus..
    I doubt the box would go any smaller to be honest.. might get away with a bit smaller but depends on the size of the computer used. Could make it really small if I had an epia type small PC.
    I'll try and sort the dimensions out at some point for you. Will be early next week probably as I haven't got a tape measure at the min...
    Phase II Peugeot 306 GLX TD
    VGA/USB Leads - DONE
    Power - Wiring ordered, waiting on info about M1-ATX
    Screen - Not started
    Boot - 40%
    Hardware - 35% - 1.4ghz Duron, 20gig hdd (for now! )
    Overall Progress = 30%
    www.306carputer.co.uk
  3. #23
    Jul 2005
    Portsmouth, UK
    Long time no update.. Had a few PM's of praise about my boot install so thought I'd update here... basically.. I ran out of money for this... needed to spend it elsewhere on my motorbike
    I have pretty much finished the boot box.. it's got a door and is all carpeted.. it looks great for first attempts... I will try to take some pictures tomorow.
    I need to change a few things in the box itself, of how the MoBo is mounted, and then get the Pc running off mains supply to install software etc. Then I can look into buying the PSU and screen!
    Update of pictures coming soon...
    Boot - 40%
  4. #24
    Jul 2005
    Portsmouth, UK
    Pics of finished PC case as promised.
    Boot - 40%
  5. #25
    Oct 2005
    How come you deleted the pics (And folder) from http://www.cwimedia.co.uk/other ?
    http://www.cwimedia.co.uk/other/306carputer/images/carpc/finishedbox2.jpg <-- totally gone.
  1. Peugeot 306 TD-OBD?
    By sygad in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-31-2009, 11:04 AM
  2. Phase 3 of my Carputer install
    By m_dunnie in forum Newbie
    Last Post: 10-31-2005, 09:51 AM
  3. Peugeot 605 TD Carputer install 8"TSK/GPS/DVD...
    By sixofive in forum Show off your project
    Last Post: 02-02-2005, 01:40 PM
  4. Peugeot 306 7.5in Widescreen install
    By alanp in forum Fabrication
    Last Post: 02-02-2005, 10:39 AM
  5. Peugeot 205 install with a portrait LCD (finally)
    By MikeHunt79 in forum Show off your project
    Last Post: 04-29-2004, 07:02 PM
