Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Thread: 2006 Scion xB
  1. #41
    Low Bitrate blackedoutxb's Avatar
    Apr 2005
    Ft. Lauderdale, Florida
    nice, yeah those wires are a ***** to run to the hatch. i put my speakers in the hatch so i know what you mean. when you upload the pics let me know.
    05 Str8 Black XB
    Check out my project so far!!
    http://www.mp3car.com/vbulletin/worklogs/61194-05-str8-black-xb.html
    Check out some other picks of my car!!
    http://www.cardomain.com/ride/751014
  2. #42
    Apr 2005
    hey man did you go to that show in orlando? if you did how was it? I couldnt make it. aight ttyl.
    05 Str8 Black XB
    http://www.mp3car.com/vbulletin/showthread.php?t=61194
  3. #43
    Constant Bitrate vairu's Avatar
    Sep 2005
    Florida
    i went man, it was awesome .. i think there was around 80 scions. i got too inspired tho and i'm wanting to change my wheels ... i did a PS of the set i want to buy from a guy out in cali:
    (Click image to enlarge it.)
    that is an older pic of my B with just the rear bagged (it still is) and it's dumped, the front is with tanabe df210's ... that was just my estimate of what the wheels would sit like, just a 10 min PS haha ... i just wanted to see how it would go with my color, but i think i just might keep my wheels and camber all around once i get the front bagged, and push out the rear wheels to make them flush
    damn i need mo moneyz, haha
  4. #44
    Apr 2005
    yeah man them rims are tight. it would look tight. yeah man you should definitel;y upgrade yo computer. mini itx is the ****. i jus cant get my powersupply to work. lol
    05 Str8 Black XB
  5. #45
    Sep 2005
    Florida
    Well here's what i went with:
    F: 18x7.5 +38
    R: 18x8.5 +35
    Hankook Ventus 215/35/18
    OTG shims
    They fit!
    Size Difference between old Rota's:
    Rear closeness (this is WITH the OTG spacers - 10mm):
    I had to roll my fenders in the rear of course with the bags ... i rolled them as much as i could and they still sit on the tire with it dumped all the way ... and i cracked the paint (only up under the fender tho) ... i'm going to sand it down and primer it anyhow ... but i need the camber shims next 8)
  6. #46
    Apr 2005
    yeah man them rims are hott. Now you need to finish the damn air setup man so yo car can be real pimp. yeah them are nice. any updates on the carpc or is it the same? aight man later!!
    05 Str8 Black XB
  7. #47
    Raw Wave lostreception's Avatar
    NY
    hey blackedoutxb and vairu i had a question for both of you you know the infamous shock when u get out of the xb... has this caused concerns for either of you in putting in a carpc i was gonna try to sqeeze my setup in the dash but im thinking twice now
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  8. #48
    Sep 2005
    Florida
    Quote Originally Posted by lostreception
    I've never experienced the shock you're talking about, but i've heard other owners talking about it ... i'm not sure if it would cause any problems with your PC tho..
    Thanks blackedout^^, i need to finish the setup, but it won't be done until over the summer. I'm going to have it done before the July 22nd show in Jacksonville. Also i'm thinking about building a new puter over the summer ... we'll see how it goes
  9. #49
    Apr 2005
    lostreception. i have never experienced this shock but i have heard of it, if you buy a good 4 guage ground wire kit it will resolve this problem. im not sure where you are going to put the pc in your dash. there is some space back there but it would be a PAIN to get to if you nedded to fix something on the computer.
    I would build a false floor in the trunk and jus put everything under the floorboards. run the wires to the trunk down the sides of the car. Its pretty simple but just takes some time.
    05 Str8 Black XB
  10. #50
    Sep 2005
    Florida
    Hey blacked out, i got some updated pics since i installed the front air struts!
    I also got 15% tint and installed a 15" Dell LCD roof-mounted. The summer heat has officially killed my PC so i'm saving up to build a lower power consuming system ASAP.
    Since these pics i've also bought the Cusco Vacanza Upper pillow-ball camber plates for my air struts ($290 from Japan >_< ... i have my front wheels cambered in like -3~ degree's. With stock struts up front i would have -8 degree's! And i also bought an RS*R Concept GTII Axle-Back .. i'll get some new pics up once i get an alignment and take out my front fender-liners so i can slam the front an extra 1.5~2" then in these pics!
  1. Scion XB everything in dash
    By dazd&confuzd in forum Show off your project
    Last Post: 01-03-2010, 08:43 PM
  2. 2005 Scion Xb Install
    By fixerofallthing in forum Worklogs
    Last Post: 03-07-2008, 06:09 PM
  3. Finished 2005 Scion XB
    By fixerofallthing in forum Show off your project
    Last Post: 03-20-2006, 10:31 PM
  4. Lilliput to M1-ATX to Scion xB
    By joecross98 in forum Power Supplies
    Last Post: 11-19-2005, 03:00 AM
  5. 2005 scion xb install
    By professorjason in forum Worklogs
    Last Post: 10-11-2005, 12:25 PM
