Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: 1987 Mustang GT Convertible MP3 Mustang
  1. #21
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    Here's a pic of the keyboard install. It isn't finished - I still have to shape some of the MDF but you can get the idea.
    Here's the airbag wheel I am going to gut. My car doesn't have an airbag in it, so this will make a perfect stealth keyboard install location.
    Here's the keyboard I'm going to use. It's USB. I have to take it out of the case and modify the bezel.
    It fits in there like it was made exactly for this application...weird.
    Here's the MDF nest for the keyboard.
    Cut the width - next cut the height.
    Now I need to shape the MDF on my sanding wheel and fiberglass the bezel I cut into the top. But you can see the rough shape.
    Here's the cut bezel - I'll fiberglass it to the top. The whole assembly will be mounted in a 'box' that can be fastened to the wheel into where the old airbag cage was bolted. You can see the guide lines I marked to shape the MDF.
    Here's what it will kinda look like - still need to shape the whole thing - then, it'll drop just below the level of where the original airbag sat. I'll mount a small piece of plexi to the underside of the airbag cover (drill out the rivets and it'll come off so I can use it to mount to the new 'box' containing the keyboard) that will fit into a routered out area so keys aren't accidentally pressed when the keyboard isn't in use.
    I'll post some more pics as I make progress!
    - Jeff
    95 Mustang GT Convertible
    My Project | Let's Go Mets! | SCT Tuners
    Project Status [===#===] [Bezel and dash creation]
  2. #22
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    How are you gonna pass the wires? (use the connector for the airbags?)
  3. #23
    Mar 2002
    Quote Originally Posted by kevinlekiller
    That's a good idea -I'll have to look how many wires they have there. I looked at the way they had it from the factory and there's just a bunch of slack wire as the wheel turns approximately 1 rotation each way. I figure where that recess is, further under the keyboard, I'll drill out a square hole through which I'll pass the USB connector and run the wire exactly as they have the horn and airbag wires. That should assure me clean wheel movement.
    - Jeff
  4. #24
    Dec 1969
    Usually airbags have 3 wires, and usb has 4 wires Lets hope yours has 4.
  5. #25
    Mar 2002
    Mine, oddly enough, has only 2... Guess I'll just have to run the wires as they did from the factory...
    - Jeff
  6. #26
    Constant Bitrate Matrix_24's Avatar
    Jul 2005
    IL
    Looking really good, I am really interrested in how the steering wheel will turn out. Keep the pics coming.
  7. #27
    Mar 2002
    Thanks! I definitely will. I plan on getting to work on it next week. I should have it all fabbed up and painted by the end of next week.
    - Jeff
  8. #28
    Oct 2007
    Way to set the standard with the 5.0 crowd... your project looks amazing so far. can't wait to see how it looks painted and finished.
  1. 05' mustang gt...now what?
    By furius styles in forum Newbie
    Last Post: 11-30-2005, 10:28 AM
  2. Replies: 0
    Last Post: 10-02-2005, 07:37 PM
  3. FS: '93 Mustang GT Immaculate!!! **MUST SEE**
    By Loco in forum Classified Archive
    Last Post: 06-16-2005, 10:22 AM
  4. 1987 Mustang GT with Laptop Carputer?
    By Hopperhawk in forum Newbie
    Last Post: 11-09-2004, 08:59 AM
  5. 2000 Mustang GT Convertible Mp3 project
    By mp3stang02 in forum Show off your project
    Last Post: 05-24-2003, 04:45 AM
