Pictures??
Well guys here we go !
I think this is almost the first Nano ITX project
I got most of the parts in from digitalww and mp3car stores
Its on the bench and working from a spare car battery, the nano and m1 atx doesnt seem to use any power.
i have had the system run for 24 hours off the battery alone and the m1 didnt detect a low voltage !!!! this was powering the board in windows, displaying only the desktop, so power consumption would be minimal, I was chuffed at that result ! means that even if the power off doesnt happen, chances of a flat battery are minimal, the longest the car stands still for is 12-14 hours, this is also good for update purposes.
The nano heatsink has reached a high temp of 43.1 deg celsius when measured with my pyrometer, and this with the fan off, I will run it with the fan on in the car as the car environment isnt as controlled as a bench
The nano itx is awesome, I dont find it slow at all (my laptop 2ghz celeron with 512MB ram) is slower on most tasks, my desktop a P4 3.0 with 512mb is slower on some tasks but obviously much faster on others
What all I crammed into the box...made up by a local perspex supplier at a cost of 12USD
The boxes dimensions are
165mm x 210mm x 65 mm all dimensions are external
The innards
1 x M1 a t x power supply
1 x Nano itx mobo with 512MB RAM
1 x Dlink USB Fm Radio - hardwired to usb port to eliminate connections and also using the audio in of the cd on the mobo, so no external connections
1 x Griffin airclick receiver
1 x 60gb 2.5 hdd
1 x notebook adapter (although if you got the right cables the nano supports this natively
1 x a t x power adapter
1 x 60mm case fan
1 x slot load cd/cdrw/dvd
all it needs is power (+ and - and ign +)
and then the usb from the creative usb sound card to work 100%
here are a few pictures !
please comment and also please let me know if you are aware of anyone with a good obd interface for the Evo8 ?
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
Pictures??
no pics?
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
some mobo and case pics
cheesh
you guys are fast
Where's the mobo?
more pics
the mobo is so small its invisible
coming in a sec
I can only post one message every 45 seconds
more pics
more pics2
