Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 91
Thread: 94 Mustang GT
  1. #51
    Constant Bitrate racerx3165's Avatar
    Sep 2005
    McConnell AFB Wichita Ks.
    Yeah i was thinking the same thing maybe i could get the bezel so i can get my dash back in a bit but i still cant decide on what TS i am going to get i keep looking at the price of the 7in. Xenarc and the 8in. Lilli and i keep reading daily looking for the Holy Grail of posts saying Exactly what one is better for my type of install, so far i keep finding the Xenarc and that is what i figured by the price. Guess im just trying to skimp and on the screen of all things i just need to fess up the money and get this car back together.
    Cars
    1994 Mustang GT Punch 240.4 2 12" Kicker Comp SOLD :(
    2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
    2003 Eddie Bauer Expedition DVD - Navigation Package Traded in for 2008 XL-7 Limited
    Car PC
    Planning
  2. #52
    Constant Bitrate Specimen's Avatar
    Jul 2005
    Los Angeles, CA
    Quote Originally Posted by Miles
    Makes sense to me. I don't have the screen yet, but think I'm going to order the headrest cover now and do a similar sort of thing.
    Last question - do you find that the screen is at a good height being under the AC vents? Are the AC controls accessible being at the bottom?
    I have a 5 spd and hope that the AC controls won't be too bothersome down there. Actually, thinking about it I only drive my stang in the summer, and the windows are down so
    It shouldn't be a bother with the AC on the bottom. Before I tore my dash apart I had the stock CD player down there and I was always using the CD player. If I could fit a CD down there, adjusting the AC controls isn’t a problem and I use the heater a lot with the top down.
    My original plan was to use the 2001+ bezel with the double din on the bottom but I did some tests and I found out that it is to cumbersome to use the screen with my automatic shifter. When the car is in park the clearance is very small from the shifter and the screen and my knuckles would hit the touch screen constantly when I place the car in park. I’m guessing that might be a problem with a stick shift as well. This isn’t a problem with the 2 single din that came with my 2000 mustang cause the Bottom CD Din is a deeper set compared to the double din that is placed forward more towards the shifter. Also the position is too low for my liking. I wanted to have the screen be high enough to be visible when my top down. You can’t build a PC in your car without showing it off. All in all I prefer to have the AC on the bottom. They’re not that attractive anyway so might as well stick them in the bottom.
    PROGRESS [==========-] 99.9% <- Are we ever really actually done with our carPCs?
  3. #53
    Jul 2005
    Los Angeles, CA
    Quote Originally Posted by racerx3165
    Go for the Xenarc 7 in. The 8 in will give you a little more display but trying to fit it in the center console is going to be tricky and probably won’t fit nicely. Also depends on what else you are going to add to the front bezel. Forget the 8 in if you want the CD-Rom in the front like mine, there won’t be enough room. For me it was a very tight fit just getting the 7 in. screen and CD-Rom in there. I placed the Screen as close to the top as possible and placed the CD-Rom just below it and it still didn’t run flush with the plastic horizontal plastic plane the runs from the top of the AC controls to the bottom of the CD-Rom. I had to cut into it about 2 inches so that my CD-Rom wood case would fit. Dropping the CD-Rom any lower and you won’t be able to get to the AC controls.
  4. #54
    Sep 2005
    Well the stang has been on hold for many reasons mainly cause it wasnt running. So now i got all the time in the world to do it cause i bought a little beater car to get me by. After looking at millions of cars the wife talked me into getting a 2006 Suzuki Aerio sx so i can keep the stang stripped down till shes all ready to finish up. No more taking something out for a few hours only to put it back in so i can go here or there.
    Cars
    Car PC
    Planning
  5. #55
    Sep 2005
    Wife promised me some money soon so hopefully ill get the fuel pump for the stangget it on the road again and get the fire in me again for this install. Im thinking if i get the screen im stuck theres no way ill back down then So my B-Day is late in Jan and thats what im telling her i want!
    Cars
    Car PC
    Planning
  6. #56
    Sep 2005
    Well since the wife tried to inpregnate a Cavalier with her truck yesterday looks to be about 12K damage, so the stang will go into the shop on monday to fix the fuel issues and get back on the road so i will be back at the CarPc income tax money is in now i need to settle on a mobo and PSU
    Cars
    Car PC
    Planning
  7. #57
    Jul 2005
    Los Angeles, CA
    Sorry to her about your impotent truck. I doubt a new car is going to pop out of the Cavalier in 9 months. Keep at that mustang. It'll be well worth it when you are done. Here is some motivation for that fire thats been reduced to embers.
  8. #58
    Jul 2005
    Quote Originally Posted by Specimen
    Did you ever get around to taking any pics of how the AC panel is bolted in there? I have some 90 degree brackets that will work, but wouldn't mind a visual of where the bracket is attached to on the car...
    Cheers!
    1997 Mustang GTS "Jenna"
    VIA SP13000, 7" Xenarc TSV, 200GB, 'modified' M2-ATX, 1GB DDR400/3200, BU-353. RoadRunner + LSXVoid
  9. #59
    Sep 2005
    OK i really have to get this car done now, i just have to settle on a mobo mainly, once that is done im good to go. I do have a P3 933 i could use but i think id rather use a 2400 amd mobile, got plenty of ram and HD's to work with
    Cars
    Car PC
    Planning
  10. #60
    Jul 2005
    Los Angeles, CA
    Na, I installed a rear cam last weekend, but It didn't require me to take off the dash. I could pop it off and take a few pics. I'm in the process of moving though so it might not be anytime soon. I admit the way I did it was a hacked up way and theres probably a better way to do it.
  1. 1987 Mustang GT Convertible MP3 Mustang
    By jzgt in forum Worklogs
    Last Post: 10-26-2007, 09:18 PM
  2. 05' mustang gt...now what?
    By furius styles in forum Newbie
    Last Post: 11-30-2005, 10:28 AM
  3. FS: '93 Mustang GT Immaculate!!! **MUST SEE**
    By Loco in forum Classified Archive
    Last Post: 06-16-2005, 10:22 AM
  4. 2003 Ford Mustang GT
    By tj!2k4 in forum Worklogs
    Last Post: 03-05-2005, 03:42 PM
  5. 2000 Mustang GT Convertible Mp3 project
    By mp3stang02 in forum Show off your project
    Last Post: 05-24-2003, 04:45 AM
