ok....
some pics ..... some questions.... here we go... this is the fitment test.. i couldnt decide to mod the buttons on the xenarc or not so... ill mod it later if i dont like it... so far so good...
[lMG]http://www.crabbnet.com/cobra_pc/xenarc_mount_5.jpg[/IMG]
the epoxy worked great... no i have to add more and sand down...
[lMG]http://www.crabbnet.com/cobra_pc/xenarc_mount_4.jpg[/IMG]
ok... guess where this came from... fellow stang..
[lMG]http://www.crabbnet.com/cobra_pc/rr_shot_1.jpg[/IMG]
here is a
video test ... using an old vaio P3 450......
[lMG]http://www.crabbnet.com/cobra_pc/test_vid_guide.jpg[/IMG]
i taped the screen in position ... then applied the epoxy putty....
[lMG]http://www.crabbnet.com/cobra_pc/xenarc_mount_1.jpg[/IMG]
[lMG]http://www.crabbnet.com/cobra_pc/xenarc_mount_3.jpg[/IMG]
its very easy to work with ... just mix part A with part B equal amounts ... mold with water on your fingers..
[lMG]http://www.crabbnet.com/cobra_pc/epoxy_putty_1.jpg[/IMG]
now for a question.... while pulling the mach460 rear speakers and enclosure i found what looks like a line level converter for input... anybody have one of these.. clean install... almost looks factory?
[lMG]http://www.crabbnet.com/cobra_pc/460_rear_harnes.jpg[/IMG]
now to remove the mach460 rear enclosure... you need to remove the amps on each side ... there is a nut under each amp.
[lMG]http://www.crabbnet.com/cobra_pc/460_rear_2.jpg[/IMG]
remove the center 4 nuts and then the 1 under each amp. also disconnect the
wiring harness to remove from the car. the harness pops out of the mounting tabs.. youll see what i mean..
[lMG]http://www.crabbnet.com/cobra_pc/460_rear_1.jpg[/IMG] ...
next to test the amps and replace the speakers... if i can get by with the actory amps for a while i will... cash is always low around christmas....
