Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 70
Thread: 96_cobra_project
  1. #31
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    Looking good, keep it up!!
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
  2. #32
    Aug 2005
    south GA
    view
    Quote Originally Posted by schpanky
    I'm using your method for my dash as well (bought a mach1 dash) and I'm finishing up the fabrication part (lilli's need a bit more TLC), I think I'm further along than you are! lol
    Ran a ton of wires from the battery to the trunk, and tapped the stock wiring harness' ACC line and ran that to the trunk as well for my power supply. I got it mostly working, but I'm waiting for xp embedded for it's EWF and minlogon
    edit: you have a inspiron 9300? I do too!
    Great minds think alike!
    dude... youre good... that little pic and you saw the 9300 ... lol .. yeah time sucks... one week my oil filter seal busted (FRAM) .... only the 3rd time i have let someone change the oil ... i run mobil1 so ... im ok... i shut it down real quick...scarry.... then same week almost on the way to the alternator shop...my alternator went crazy.... bad bearing.... bought an autozone for 212.00 ... i know i know... lasted 600 miles.... bad bearing.. had the original rebuilt for 83.00 .. and it runs like a top.. now i can get back to the carpc...lol... so where are you puttin the pc?
    the rebuilt alternator failed after couple months... seems they didnt replace all of the bearings.. only the defective one... so I ended up purchasing a new alternator from ford. so far so good.
    69 Mustang
    408 clevor AFD 2v heads - Viper T56
    Audio:RUX-C701, PXA-H701, MRV-F545, (2) MRD-M1005, SIR-SC-H1, DMHD1000, Dayton Audio: (2) RS180-4, (2) RS28F-4, (2) RSS265HO-44 DVC
  3. #33
    Low Bitrate schpanky's Avatar
    Jul 2005
    Quote Originally Posted by crabbdaddy
    hehe, yeah, I have one too and I saw that wierd vent thing next to the page down/backspace buttons and that it had a white top, decent laptop so far... ANYYYYYhow
    I'm mounting my PC in the trunk, I have a vert so there's no seperation from the trunk to the interior of the car (other than the film-like rubber tonneau thing ), wiring was pretty simple, I'll finally start a worklog later on, maybe tonight
    I put a tiny fused block from off the battery from a 6-disc pioneer cd changer with like 4 guage wire into the car, put a distribution block there, and ran 12V, ACC, and ground on the driver's side and another 12V, ACC, ground to the other side for an amp when I finally find one (I have no idea how to find a good amp)
    I know for a fact that wiring for the speakers is going to suck, but I haven't got that far yet
    AND QUIT KILLING YER PARTS!
    1995 Ford Mustang Convertible
    DSATX | Shuttle XPC SN41G2Bv2 | 619GL-70NP | CF 1.6 (which is still unusable in the car!)
  4. #34
    Aug 2005
    south GA
    bezel update
    ok,
    sanding .. .sanding ... dremel .. and more sanding....
    seems the porpatch does work ok..... its easier to sand than i thought... and the tuff spots i used a dremel.... the cool thing is that the gloss black sands down to a grey that actuall matches the bezel color.....
    the gloss black helps notice the low spots .. looks worse than it is ... to touch the low is onle slightly low .. less than a mm. so im going to fill with bumper filler from bondo .. and sand that down .. at least thats my plan at the moment.
    and one more after a little bit of sanding .. and removing the high spot at the bottom right with the dremel....
    man its hard not to rush.... patience grasshopper..... lol
    69 Mustang
  5. #35
    Mar 2005
    Laurel, Maryland
    I know exactly what you mean about patience.....but man it's worth it!!! It's looking great....keep it up and keep us updated!
  6. #36
    Raw Wave tj!2k4's Avatar
    Oct 2004
    looking good, keeping an eye on this.
    no criticism here: personally I would've kept the ac controls low, but I understand you were looking for double-din, and the newer model bezel afforded you that.
    I just wasn't real thrilled with the screen being so low; I think it makes it more difficult to read.
    Anyway, good work, and that was just my $.02.
  7. #37
    Aug 2005
    south GA
    Thumbs up screen location
    Quote Originally Posted by tj!2k4
    yeah ... that was my first thought... so i droped the AC controls down to the bottom .... drove around like that for a few weeks...but when i played around with the mounting of the xenarc screen.... i couldnt keep the sun off of the screen..... seemed i would have had to tint the front window half way down... and thats not gonna happen... all other windows are tinted .so ... i chose the stock somewhat recessed 03' bezel...... would be interesting to know if others have the screen mounted higher and how they are dealing or not dealing with the sun ....
    69 Mustang
  8. #38
    Aug 2005
    south GA
    shematics
    ok....
    seems these are hard to find....
    i posted them in another link...
    CarPC -> Amp (Headunit-less)
    enjoy... ill try to verify the schemas this weekend....
    69 Mustang
  9. #39
    Aug 2005
    south GA
    audio setup
    ok,
    i finally decided on the audio setup. and i hope to make some progress on the overall setup soon. i took a semester break from class and a few projects.
    Alpine RUX-C701 Controller
    http://www.alpine-europe.com/content...R-PXA-H701.htm
    Alpine PXA-H701 Processor
    http://www.alpine-usa.com/en/product...model=PXA-H701
    Alpine MRV-F545 Amp
    http://www.alpine-usa.com/en/product...model=MRV-F545
    Polk MOMO MMC6500 Components 6.5" / 1"
    http://www.polkaudio.com/caraudio/products/mmc6500/
    Polk MOMO MM2104 Subs (2) 10" SVC 4 ohm
    http://www.polkaudio.com/caraudio/products/mm2104/
    also decided on a soundcard with optical out.
    Chaintech AV-710
    http://www.chaintechusa.com/tw/eng/p....asp?PISNo=199
    looks like im purchasing most of the alpine components from ebay seller 310audio.
    hope to make some progress on the bezel this weekend... i have done more work on it.. but pictures didnt turn out worth posting. i purchased a 90 attachment for my dremel to do some better sanding on the angles.
    69 Mustang
  10. #40
    Aug 2005
    south GA
    bezel progress
    ok,
    a little bezel progress... im learning.. and yes its been over a year since this project started....
    i added some filler primer... couple more coats to go. so far so good.
    ill add another coat tomorrow.. and maybe ill be ready for more sanding
    still waiting for my audio gear to arrive. it should arrive by the end of the week.
    69 Mustang
