Results 21 to 30 of 31
Thread: 2005 Vw Gti
  1. #21
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by kbyrd
    WebDog: Thanks for the write up. Now I understand how you did it.
    A few questions:
    - What did you use to cut the bezel lilliput bezel without cracking it?
    - So, you secure the screen to the front using the factory mounts, right? How does this whole piece secure to the dash?
    I used a lexan glass cutter and then a x-acto to finish it out...
    Yep it does use the factory screen mounts...
    Today im gona make the mounts for the dash part of it.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  2. #22
    Ok i now know what im gona do to mount the screen to the dash...
    i made some lexan tabs that i glued to the bottom and that will snap in to the radio cage..
    On the top im thinking ill have some tabs but they will bolt in or something... not sure yet ill update later with more info on that.
    1990 Jeep Cherokee
  3. #23
    Well i had to remove the tabs since it made the screen and housing back not go on so its just velcroed in place right now... Its a pretty good hold.
    Im gona work on mounting it more secure tomorrow...
    Pics later tonight, time for dinner...
    1990 Jeep Cherokee
  4. #24
    Jan 2004
    Did you have the original plexiglass frame machined somewhere? How does one go about getting that done?
    2002 Subaru WRX - Silver
    -FP18G turbo
    -Walbro fuel pump
    -Modified OEM 840 CC Injectors
    -TurboXS: UTEC, turboback, uppipe, intake
    -Blitz FMIC
    -STI cluster
    -17"x7.5" SSR Competitions
    -Tein Flex coilovers
    -NOS 50 shot
    -2004 rear conversion
  5. #25
    Quote Originally Posted by imprezive one
    i just went to a local plexiglass shop and they cut it while i waited... cost about $25
    1990 Jeep Cherokee
  6. #26
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You can also cut plexi with a dremel tool and a rotozip bot. then sand the edges smooth.
    I used to cut it with a jigsaw, which does work but can crack the plastic if you aren't careful. A bandsaw or circular saw works much better for the outside.
    For the inside, the dremel/rotozip bit works well.
    Want to:
  7. #27
    ok well i got the system installed but now i got some alternator noise..
    I think maybe its becuase i got my ground from the front of the car, i think i will try a ground in th back maybe where the amp is grounded...
    One thing i noticed on the monsoon HU on the sticker listing the cables that there is a "amp on" one does anyone have any info on that one? would we not have to worry about 5V if we figured out how to use that one?
    Or is that the HU turn on?
    1990 Jeep Cherokee
  8. #28
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    Quote Originally Posted by WebDog
    I tried grounding on your advice (mobo mount hole to ground that supplies PSU), and it introduced an alternator whine without removing the hard drive chatter. So, I pulled it and the whine went away.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
  9. #29
    Hmm thats wired ill try that after work, i wonder why when i had a cable go from mobo strait to the 12 v socket ground that i didint get noise?
    1990 Jeep Cherokee
  10. #30
    Nov 2003
    Northern Arizona
    I'm 99% convinced my noise is coming from the 12V feed to the 5V regulator. Right now, that 12V line is a molex from the PSU. I'm planning on drawing it from the car and controlling it with a relay.
    Did you ground your 5V regulator?
    My worklog.
  1. 2005 Volkswagen GTI
    By kbyrd in forum Worklogs
    Last Post: 11-05-2007, 04:43 PM
  2. Worklog: Wasabi's 2001 VW GTI VR6 Carputer
    By Wasabi in forum General Hardware Discussion
    Last Post: 10-08-2005, 02:11 PM
  3. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 01:51 AM
  4. VW Polo GTI - Xenarc in dash- Pics
    By live2themaxuk in forum Fabrication
    Last Post: 11-09-2004, 05:13 PM
  5. 1998 VW GTI VR6 Project
    By Stavros in forum Show off your project
    Last Post: 01-27-2003, 12:16 PM
