I'll be posting all the things I do to the first postEasier to read my progress that way...
Okey...
So I decided to build my first carputer in my little Renault!!
This is how it looks at the moment:
It is a crappy standard 1,2 litre "shopping bag"
I'm going to do a lot to this car thoughI'm currently going trough an engine rebuild... a 1,4 litre version. A bit more power to make the ride more smooth...
Also the interior is going to be rebuilt for the most part!
As for the carputer part:
As a screen I will be using a Sony psone screen which I bought from huuto.net (auction site like ebay, but here in Finland). I've been fiddling around with the screen and took it apart so I could make an VGA-mod get better quality
Though for now I'm trying to find a broken psone so I'd get the connector from it and build a vga --> psone av converter cable...
The first plan was to use a Dell optiplex GX100 (intel 433MHz) desktop computer! Got it from a friend for free...
Plans have changed. Messing around with powerstrip has confirmed me that the integrated intel 810 chipset will not work with the psone screen :P
So now I'm going to use my home pc (450AMD with ATI radeon...) and use the dell as my home pc.
I'll build a some sort of regulator for the screen and power the pc via inverter (no I'm not going to use a dc --> dc converter because they cost a ****load of money here in finland and no I'm not going to buy anything from eBay)
I think I'll have to rebuild my subwoofer box in order to fit the computer to the trunk
31.10.2005:
Oh yeah...
Currently I play mp3 music with my creative usb-mp3player thingy... I've got it hooked up through my dodgy pioneer HU:s ip-bus connector! Just sticked some wires to the ip-bus connector and soldered rca connectors to it. Works just fine
16.11.2005:
I've soldered a vga cable to the screen and tested it... IT'S WORKING
Only problem with it is that the screen flickers alot... When I play video it looks fine but all the stuff that doesn't move flickers... I'll have to search if anyone has had the same problem :P
This is how the screen looks through the composite input:
Signal from my DVD-player...
Some day I'll take photos of the vga-mod picture quality...
24.12.2005:
Merry Christmas everyone
And the same in finnish...
Hyvää Joulua kaikille Suomalaisille
Not much really happened to the car... I did buy a "new" pc to my house from my school for 50€ (1,2GHz AMD)! So now I can strip up my old pc and start mounting it in the car
I´ll be posting pictures as I start on that...
Hey cool, I used to have a 1.4 and they're reasonably fast! That thing used to lean like a ***** on corners though and it had NO GRIP whatsoever - moved to it from a mini, so the difference in cornerning was like night and day! Still loved that car though - so solid and I used to bash things out the way with it :P
Get a bodykit on that and transplant a renault 19 16V engine and you got a mean little car there boyo!
16V engine would be nice...
But they are so expensive around here and I would have to upgrade all other parts also :P
I used to drive around with a GT Turbo modelThey are very nice cars indeed... Now my brother owns it!
I was actually considering a -02 Clio 1,2 16V engine transplantDon't just have time right now for bigger projects :P
As can be seen in the first photo, I've lowered it! Goes through corners much better nowNext spring (winter is coming, bummer
) I'm going to put 15" wheels to it. Have to make some modofications to the wheel arches though!
New paintjob coming someday also...
yeah i can see you lowered it. I say stick with those wheels to avoid arch mods. You might get rust problems and those wheels look retro renault cool! Save the money and get some brakes off a clio 172 and a 2 litre engine or if you are running on carbs fit a turbo - 1.2 turbo!![]()
Turbo would be nice
But I'm not going to do any major modifications before I get the paintjob etc. done with the car...
Besides... putting a clio172 engine in it is impossible with finnish lawsAnd those engines cost ****loads of money over here and I'm going to keep a rather tight budget!
So now I'll be working with the inside of the car![]()
I know of a brand new pug 106 gti/saxo vts engine going for £450 but i suspect shipping would cost a bit.
seeing as theough you are in rally country convert it to 4wd![]()
mid engine rear wheel drive sounds much nicer![]()
