Forgot some pics of the car, so here we go:
Currently purchasing parts...here's the list of items purchased so far:
VIA EPIA MII10000
512MB RAM
M1-ATX
Super 7" VGA Touch Screen
Spare dash to mould screen into (rather not drive around with no dash!)
Slim DVD-RW/CD-RW with external USB enclosure
Kenwood 4x50W RMS amplifier
4 port Powered USB Hub (up front for touch screen, slotload DVD-RW)
200GB 3.5" IDE HDD. (If i have trouble with 3.5, then i will switch to 2.5, but thought id give the cheaper option a shot first)
Total spent so far: ~$1000 AUD.
Projected spendings: $1,770 AUD - Lets see how much over I go!
Have currently got my system hooked up to a standard ATX power to test indoors, with a CD drive and old HDD running from the ATX.
Connected the +12V and SW (Ignition) pins of the M1-ATX to a standard ATX molex connector yellow wire (+12V) and GND on the M1-ATX to the corresponding black wire (Ground) of the molex connector.
The green and a black wire from the standard ATX connector have been shorted to force the power supply to turn on without having to connect it to a motherboard.
Have also taken apart the power adapter that came with the 7" screen and disconnected the DC barrel wiring. These wires are then connected to +12V and GND from the ATX (same molex as the M1-ATX is connected to). Powers up the screen for testing.
Waiting to pick up my XP CD from home before I can install it and start setting up the software side of things.
Things are finally starting to take shape!
Jarrod - Holden VX S!
Where abouts do you plan on mounting the screen, where the stock stereo is, or in that gap underneath it?
Fox Mulder
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
I did a little test fit of the LCD and slotload DVD-RW a few days ago, and here are some pics of the result.
Few more pics....
I got a stock Holden VT stereo from ebay ($1+shipping) and detached the face plate of it to use as a fake face to hide the LCD when its not in use. This way the car will look 99% stock (just an older model stereo face) when not in use.
As you can see in the pics, the fake face plate is missing some buttons (fwd, rew, eject), but i have those sitting on my desk waiting to be glued into place.
The area where the slotload DVD is installed simply pops open and closed with the push of your finger to access the DVD. Oh..and DVD enclosure will be molded into place so that I dont have to hold it up with my finger all the time
Not sure if I will end up using the plywood LCD holder as the edges arent too straight. Might just buy some plexi and cut that to shape to create the holder for the LCD bezel. Will plastic weld epoxy glue stuff hold plastic to plywood?
Yup.Originally Posted by Jarrod
Nice job on the screen concealment,my only concern is that the screen looks a little too far back and too low to see and/or use.
Any sufficiently advanced technology is indistinguishable from magic - Arthur C. Clarke
When i put the LCD in for the test fit, i put it in further than I needed to to clear the fake face depth, but I could still see all the LCD area from normal driving position, so that shouldnt be an issue. Also adds a little shadow from direct light issues if the LCD was level with the dash.
Looks like its coming along well jarrod.. good to see another commodore owner on here![]()
VY Commodore S Pack HotHouse Green
SP 13000, Precision Response Audio, Stealth Install.
Progress: 60%
Hardware Bought, Install Time.
My Worklog
Mobilus - My Frontend, 55% done
V0.7.1 Now Released
Thats hilarious how you've chopped the front off the old stereo for the stock look.. Nice one..
Clean car but needs to be lowered.. lol
CAR INFO HERE
"He who dies with the most toys, wins".
