Results 1 to 10 of 11
Thread: 2000 Mitsubishi Eclipse with 8" LCD, Relocated Stereo & AC Controls
    May 2005
    Thumbs up 2000 Mitsubishi Eclipse with 8" LCD, Relocated Stereo & AC Controls
    ALL DONE!!!! 2000 Mitsubishi Eclipse with 8" LCD, Relocated Stereo & AC Controls
    I plan on having this completed by the end of the coming week, but probably will be done sooner! I spent about 6 hours today on relocating the head unit. Step 2 will be moving the AC Controls to the lower center console, Step 3 will be the 8" Lilliput 809GL monitor and PC installation.
    Step 1: Complete
    This turned out better than I thought it would. It required no real fabrication (read: no bondo, fiberglass, etc). I used a heat gun to slowly mold the front fascia of the clock pod and a dremel to dremel it out so the radio would fit from the rear. I also dremeled the hell out of the original clock pod and center speaker mounting brackets so the radio would fit. The clock pod cover was originally so rounded that the stereo face itself wouldn't even fit where it is now just setting it there from the front. The heat gun worked wonders! As usual, looks way better in person.
    Everything works including the motorized detachable face.
    Constant Bitrate racerx3165's Avatar
    Sep 2005
    McConnell AFB Wichita Ks.
    Lets see a pic from a little further back
    Cars
    1994 Mustang GT Punch 240.4 2 12" Kicker Comp SOLD :(
    2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
    2003 Eddie Bauer Expedition DVD - Navigation Package Traded in for 2008 XL-7 Limited
    Car PC
    Planning
    Tainted Love Cris's Avatar
    Romania
    Nice! Where are you going to relocate the AC controls?
    Spring Hill, Florida
    Quote Originally Posted by Cris
    I would suspect in the din opening below the stock location (can be seen from the first picture). At least that is where I would put them...
    2005 Black Chevy Impala
    Jul 2005
    Ontario
    hu looks good, what model is the pioneer hu?
    May 2005
    I plan on putting the AC controls into the lower center console in front of the shifter. The screen will fill up most of the area where the current radio/pocket/ac are located and should leave me enough room for a media card reader. The screen doesn't get here til tomorrow so I'm not for sure on space there.
    Pioneer DEHP8600MP
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    instead of a media card reader why dont you put a slot load slim drive or maybe even a slot load fullsize dvd drive? that would look sweeeet
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    May 2005
    I measured it just now and according to the size of the 809gl it may even be hard to fit a media card reader in the space I have, I guess I'll find out tomorrow.
    I had considered putting a DVD drive in the center console lid facing forward. My car is the RS, it came with no center console lid, so I made one.. I'd just have to redo it a bit to fit a drive in it, not a big deal. I don't want to put one in the front cause I'd use the media drive more often and I don't want to wait to order one
    WooHoo! Just got the manual push/pull heater cables extended! They work great. I used ring terminals for connection points and positron bicycle gear cable with reinforced bicycle sheating.
    Constant Bitrate blacklancer's Avatar
    Nov 2005
    Los Angeles, Ca
    looks good so far. keep us updated.
    May 2005
    Smile
    This is taking a lot longer than I wanted it to! But doesn't it always?
    The fiberglassing of the lower dash took a lot of time but tonight I finally started priming it. I've got 4 coats of the finish coat on the upper piece with the screen and 2 coats of primer on the lower dash piece (for the heater controls). The textured black spray paint I got from Home Depot looks like a match to the factory interior, tomorrow I'll spray some matte clear and hopefully have time to finish it.
    I have lots of pictures I'll be posting along with the finals either thursday or friday!
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. My 2000 Mitsubishi Eclipse Setup
    By mestre in forum Show off your project
    Last Post: 04-30-2004, 02:19 PM
  3. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
