Results 1 to 7 of 7
Thread: 01 Goldwing 1800 BikePC
    Oct 2005
    westyorkshire - Fishkill NY (IBM)
    ok work in progress
    There are more images on my webserver
    http://www.nigelf.dyndns.org/gallery
    Due to the limitations of this site (max number of images = 15) i have moved to Digital-car.co.uk where no limitation seems to be made.
    Nigel Fenton
    Oct 2005
    isnt the touch screen plastic and therefor water resistant ?
    Aug 2005
    Its plastic, yes, but the seams in the casing aren't sealed. I think you're going to run into problems due to water unless you silicone it all shut. And then you may have overheating problems.
    I love the idea though.
    Also, why didn't you flush the screen in? Was there an unmovable structure underneath the bezel where you cut?
    In the works...
    Dell GX240 SFF
    P4 1.8GHz, 256 RAM, 160GB HDD
    8" Lilliput (fab work completed - F-150)
    My worklog
    Misc crap FS - OLD laptop (w/ adapters) | Sony memory | USB key | Printer Dock, etc
    Oct 2005
    yes the small lcd has a pokey out bit and i dont have a replacement plastec for that! may be in mark II.
    I intend to seal around the screen (front panel) with a small bead of silicon and sort of box the rear away from moisture with a small fan to keep things cool.
    nigel
    Low Bitrate Daley's Avatar
    Oct 2005
    H-Town
    Hmm, awesome idea, but I'm concerned about you losing the functionality of the original display. It contains things like speedometer and other indicators. I used to work at a Honda dealer, and absolutely *love* the new GL, and have even thought about the idea of a bikePC myself. I simply couln't come up with a good place for the display..
    Best of luck, and keep us posted!!
    To find your favorite restaurants in Houston, check out http://www.thehubgrub.com.
    If it's not fun, you're not doing it right!
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Marvelous idea!
    Love it, really! Keep 'em pics a-comin' !
    Aug 2005
    Here's a thought... what if you snipped a small piece of air filter material to attach to the grill area on the back of the case? That should let the air still flow through enough to cool it, while wicking the moisture out of the air.
    In the works...
    Dell GX240 SFF
    My worklog
  1. 2001 Goldwing Bikepc :)
    By Nigelfenton in forum Show off your project
    Last Post: 11-11-2005, 04:10 AM
  2. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 08:15 AM
  3. AutoTap ODB-2 cable...
    By coleman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-28-2004, 11:13 PM
