Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: 02 Land Rover Freelander
  1. #21
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Intresting stuff....
    Terran
  2. #22
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
  3. #23
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Excellent solution. But I want to see the salad tongs! Got any photos of where they are?!
    Want to:
  4. #24
    Jul 2005
    NYC
    here are the tongs, kitchen-aid i think.
    Unfortunately, I don't have a picture of the springs without the monitor. Here is where they are.
  5. #25
    May 2006
    Hello,
    I just receive my second-hand 1998 Freelander.
    I was hopping using the same "cup-holder trick" as you, but, I was suprised to see that my freelander doesn't havec this Cup holder. I only have a rubber pad. I could consider rebuild a piece, but, if should be easier to buy the same cup holder as you.
    Do you know if it is possible?
    Do you have any advises or recommendations about building this kind of system?
    Thanks,
    JC
  6. #26
    Jul 2005
    NYC
    as far as finding the cupholder ... when i started, i searched and found the price is roughly $45 for a replacement cupholder. i am not sure where i saw it, but it can't be too hard to find. worst case, maybe you can call a dealership and they can get you a replacement part, although it's a little more expensive.
    i built the lcd mount the first time as a temporary solution. i installed the rest of the car computer and ran the system for a few months. since then i have been contemplating how to permanently mount the screen (still in the same place). i took apart the cupholder/screen last week. i decided on a better way to mount it, using aluminum angles on each side of the screen. the one problem i have is figuring out how to open and close it. the previous method involved a "stick" that was put through the two holes. i have been sketching some push buttons, latches, etc. the problem is that there is almost no room to mount a latch behind the top of the screen. i'll post pictures of my current progress soon.
    as far as advice ... the cupholder is perfect for my car. if i were in your shoes, i would buy one and do it the same way. if you do use a cupholder, take it apart strategically. the front flap can be cut away, but the back flap is mounted well on pins, with a nice gears for smooth movement. just attach the top flap to the bottom and trim all the excess material away.
  7. #27
    Dec 2009
    Dear friend, I have 02 freelander in hand now, really need your help, would you please check your private message? I'm having trouble with screen now. thank you
  1. 2004 Freelander HSE
    By nibix in forum Show off your project
    Last Post: 04-02-2008, 06:15 AM
  2. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 08:15 AM
  3. Landrover Freelander wiring harness and mounting
    By cenneth in forum Car Audio
    Last Post: 07-21-2005, 06:01 AM
  4. LRALPX on a 2004 freelander?
    By nibix in forum Car Audio
    Last Post: 06-23-2004, 11:52 PM
  5. Freelander newbie and power question.
    By nibix in forum Newbie
    Last Post: 05-29-2004, 08:43 PM
