Page 1 of 6 123456 LastLast
Results 1 to 10 of 57
Thread: 1995 Volvo 850 T5 -- 2 din install
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    After a long delay (other projects, and general lack of interest), my project is progressing.
    The plan is relatively simple: take a duplicate stock deck (2 din), fit a 7" TS LCD into it (recessed a bit), stick the machine in the trunk and still allow the LCD deck to be removeable.
    Hardware
    EPIA M10000
    512MB DDR
    M1-ATX (died before I can put the PC in)
    OPUS 90W DC-DC
    27GB WD (will get something bigger later)
    SP-719 7" TS LCD
    Stock Layout
    Bad photo, but you can see where the stock deck is. The entire dash is angled towards the driver a bit, so viewing angle is more or less proper. The deck pulls out with two clips and slides on rails. My goal is to retain this ability with the new deck.
    Issues
    One major is issue is that there is no space for buttons or knobs on the deck with a 7" LCD fit in there. Having atleast buttons is a MUST. But I don't want to butcher the dash up to have this luxury. If you look to the right of the shifter in the center console (photo below), right under the passenger heated seat switch, you can see there is a blank space (unlike the left, which has the Winter/econ/sport mode selector). The plan is to drill a hole into the wood trim straight through to the bottom of the center console (there is PLENTY of space under there) and put in an ALPS rotary encoder w/ 8-way switch (ala iDrive). Cap that off with a relatively clean and small knob, and perhaps add orange LEDs under it to so that it fits with the rest of the center console's lighting.
    Fabrication
    Okay, so basically now that I got all my parts I started to work on the fabrication of the "deck-LCD"
    Stock deck with everything other than the cage left in. You can see the little plastic clips upfront sticking out, I want those to remain in the deck.
    Starting to dremel out the front plate.
    Test fit. From here you can also see the rails (black) which the deck slides on into the dash. Isn't that a perfect fit?
    Stock bezel cut out. Very rough cuts since I'll be bondo'ing it eitherway.
    Temporary fit of the LCD's bezel under the stock bezel.
    The fitment in the above photo has the LCD too far back. I am going to bring it much further out. Maybe only 3-4mm sunk in, but definitely not 8mm.
    More to come as I work on it!
    Oh and even though everyone has seen these (or has em), the mobo and PSU.
    May 2005
    Mpls, MN
    ohhh, looking good! that fitment is just picture perfect...
    Constant Bitrate blacklancer's Avatar
    Nov 2005
    Los Angeles, Ca
    looks like its working out nicely so far. keep us updated.
    Feb 2005
    Quote Originally Posted by jon102034050
    Yeah, it fit pretty well! However it's not 100% centered. The viewable part is not centered onto the panel, the part with the CCFL is 2mm longer.
    Tainted Love Cris's Avatar
    Romania
    This looks really promising!
    That's an awesome car btw.
    Constant Bitrate UnsanePyro's Avatar
    May 2005
    RI
    Hey man, congrats on getting it going. I just saw a picture of my house with my old 850 in front of it and damn, I want one again, was actually looking around ebay and some other listings, good luck with the project, I'm sure coming from you it will be impressive.
    :: '97 2.5 TL :: CarPC 1.0: Complete :: CarPC 2.0: 95% ::
    Feb 2005
    Quote Originally Posted by Cris
    I think it's looking promising as well! Hopefully it works out as good as I hope it will.
    Thanks! It's a fun car.. if only it was a bit bigger (it's midway between a 3-series and 5-series in terms of interior room) and wasn't FWD!
    Feb 2005
    Quote Originally Posted by UnsanePyro
    Thanks man! How's your TL going? You should visit VS sometime again...
    May 2005
    RI
    Quote Originally Posted by LiquidKernel
    The TL is going pretty well, I've got a couple little issues with ti right now, but really stuff that is my fault so I can't complain.
    I actually opened VS back up, I think I'm gonna start posting over there again, it's a cool group of people.
    Did bing move out to Cali?
    Romania
    What's that I read in your sig: custom LED brake lights, BOSCH E46 Single-Xenon retrofit? Could you post spme pics of that?
  1. XC90 Install - am I the first??
    By klokman in forum Worklogs
    Last Post: 02-13-2007, 01:12 AM
  2. 1995 Mercury T-Racer install finished!
    By Tidder in forum Show off your project
    Last Post: 06-20-2006, 05:00 AM
  3. Lilliput LCD install for Volvo 850
    By Rickles in forum LCD/Display
    Last Post: 01-16-2006, 07:02 PM
  4. 2001 Volvo S60 Install
    By jcdillin in forum Show off your project
    Last Post: 09-27-2005, 06:55 PM
  5. 2004 Volvo Completed Install Link
    By StaggRLee in forum Show off your project
    Last Post: 02-16-2005, 12:47 PM
