A bit further on the screen area now. Filled the gap down the bottom in with MDF and glued it solid. Filled it quite a bit with Aryldite as it needs to hold a bit of weight and be able to with-stand tightening of the two screws that hold it to the dash. Also did a bit of spraying with Putty Primer/Filler which will help to clean up the small scratches and find the bits that needs fixing up. Awaiting it to dry now so it can get sanded again.. and again.
LinkBack URL
About LinkBacks
