Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Dracos's 3rd CarPC install!
    Variable Bitrate Dracos's Avatar
    United Kingdom
    Dracos's 3rd CarPC install! LOADS OF PICS!
    ...in a Fiesta Mk3.5 SI this time (all the kit used in this install was taken from my renault install).
    From conception to where it is now has only taken me 6 hours
    Tomorrow should be very VERY productive..
    note: here are my 1st 2 installs:
    1st ever: Renault 19 Phase 1
    2nd: Nissan Sunny Pulsar GTi-R
    Pictures? you REALLY wanna see?
    OK THEN!
    The dash I have to work with:
    moving on, the screen bezel (ripped out of the renault),
    the place I want to put it,
    and after some hot-glue to test fit (before any cutting is done!)
    the angle of the screen in relation to the dash,
    after some cutting of the main dash piece and once again, hot glued in for a test fit!
    ok from here, i removed the hot glue from the front and reapplied to the back, then i started with the glassing.
    I removed the button portion of the bezel, but only the button portion i kept above it and below it and glued/glassed it back together to look 'pretty'
    United Kingdom
    and now just some photos before sanding and the building of the bottom with wood and glass (dash should look remotely stock when finished!). You can also see in the 'sturdy' photo, that after removal os some of the dash plastic, i left a flimsy part, so I sturdied it on both sides with a nice lump of glass paste. Enjoy - more updates tomorrow.
    thanks for looking guys! comments?
    Tainted Love Cris's Avatar
    Romania
    What happened to the Renault install?
    I see you've opened your screen this time...
    United Kingdom
    the renault install didnt allow me to only mould the bezel, so i had to install the whole screen as one unit.
    As for the renault install? the car turned into a **** heap on wheels, everything started going wrong with it, so i scrapped it and bought the car i have now.
    United Kingdom
    BIG UPDATE! and of course, loads of pics!
    How the day started:
    and how the day finished:
    WOW!
    yes, I even impressed myself.
    anyways, the step by step pics
    First of all I built the base up with card and got it shaped mostly how I liked (sorry, forgot to take pic).
    Then I gradually applied fiberglass
    in this one you can see the card (the white)
    keep on applying...
    United Kingdom
    now the main application to cover it all and build it up to the right thickness
    and with the screen in place for screenshot purposes
    After the first sanding:
    and how i ended up after it:
    DUSTY!
    it was then washed, and the 1st layer of normal filler was applied, sanded and then washed again:
    at this point I thought it best to apply a layer of primer to see where i needed to pay attention to.
    as you can see, not actually too bad!
    anyways, a lot of sanding, priming and filling (repeat) ensued.
    I then finally ended up with:
    and the finished product....
    painting and test-fit tomorrow
    Newbie silverbackman's Avatar
    Aug 2005
    Calgary, AB
    Nice!
    That's gonna look stock when you get it in.
    Keep the pics comin.
    There is no such thing as gravity, the world just sucks!!!
    United Kingdom
    ok, a painted update!
    the spray gun i used fooked up and decided it wanted to spatter rather than spray. so now, it looks like:
    not too bad though, ill sand it down smooth AGAIN, and try with an aerosol instead of my gun. **** happens.
    Constant Bitrate TheLandYacht's Avatar
    Oct 2005
    Austin, TX
    Quote Originally Posted by Dracos
    Actually...that spattered look doesn't look too bad...not stock, but groovy in its own way nonetheless.
    United Kingdom
    im going to be borrowing 2fastmr2's spraying gear to spray it up properly on saturday. so for now, a lot of sanding and refilling has gone on and its being sprayed back to the hi-build grey primer that you can see in the other pics.
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. 350Z CarPC install.
    By TeaVirus in forum Show off your project
    Last Post: 08-13-2007, 11:33 AM
  3. car i pay one of you guys to help me install my carpc setup?
    By megagoo in forum General MP3Car Discussion
    Last Post: 11-19-2005, 10:36 AM
  4. 1993Opel Vectra carpc install
    By [mp3]neo in forum Worklogs
    Last Post: 11-12-2005, 09:22 AM
  5. I might put the CarPC on hold ATM and get this.
    By Skraggy_uk in forum Car Audio
    Last Post: 11-04-2005, 03:38 AM
