2000 Pontiac Trans Am V 2.0 (Updated 27 June 06 with video)
this is the SECOND worklog on my TA carputer due to some minor problems with the old setup which eventually led to motherboard failure. Here is the first worklog. Since I just came into a little bit of money to purchase some more gear, I figured why not re-design everything?
The reason my motherboard bit the dust was because in my original design, everything was packed into the dashboard and I ended up busting a capacitor off the board. So this time, I am creating a small fiberglass enclosure behind the driver's seat to hold the powersupply, motherboard, and hard disk. Here's a pic of the new location with the components laid in place to make sure there's enough room:
http://www.mobile-effects.com/module...serialNumber=1
Next, I started sreating a fiberglass enclosure to hold everything. First, I taped off the whole area using 2" masking tape and cardboard:
Then I smeared a coat of vaseline over the tape to keep the fiberglass from adhering to the tape/cardboard:
Next, I laid two layers of 'glass to the area using fiberglass resin, fiberglass matt, and a couple of cheap 2" chip brushes:
I purchased a sheet of 3/4" thick pvc plastic from McMaster-Carr, and cut some to form the inside surface the components will mount to. After I screwed it in place inside the fiberglass form, I filled the hollow spaces between the two with expanding spray foam, and trimmed it with a hacksaw blade:
That's all i've done for now- I'll post updates as they happen.
