Page 1 of 6 123456 LastLast
Results 1 to 10 of 54
Thread: 2000 Pontiac Trans Am V 2.0
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    2000 Pontiac Trans Am V 2.0 (Updated 27 June 06 with video)
    this is the SECOND worklog on my TA carputer due to some minor problems with the old setup which eventually led to motherboard failure. Here is the first worklog. Since I just came into a little bit of money to purchase some more gear, I figured why not re-design everything?
    The reason my motherboard bit the dust was because in my original design, everything was packed into the dashboard and I ended up busting a capacitor off the board. So this time, I am creating a small fiberglass enclosure behind the driver's seat to hold the powersupply, motherboard, and hard disk. Here's a pic of the new location with the components laid in place to make sure there's enough room:
    Next, I started sreating a fiberglass enclosure to hold everything. First, I taped off the whole area using 2" masking tape and cardboard:
    Then I smeared a coat of vaseline over the tape to keep the fiberglass from adhering to the tape/cardboard:
    Next, I laid two layers of 'glass to the area using fiberglass resin, fiberglass matt, and a couple of cheap 2" chip brushes:
    I purchased a sheet of 3/4" thick pvc plastic from McMaster-Carr, and cut some to form the inside surface the components will mount to. After I screwed it in place inside the fiberglass form, I filled the hollow spaces between the two with expanding spray foam, and trimmed it with a hacksaw blade:
    That's all i've done for now- I'll post updates as they happen.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    you never use ur back seat?
    Live mp3Car Facebook Chat
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by Sonicxtacy02
    Only to throw stuff in, The TA's and camaro's have zero leg room for rear passengers, and I'm 6'4" tall, so no one sits behind me ever.
    WORKLOG
    Webpage
    Low Bitrate shuggyboy's Avatar
    Jan 2006
    sweet.
    That should look sweet, lookin forward to seein some more pics :-)
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    having a pc back there is a good excuse to not have to cart all your friends around all the time..... LOL
    Nice work on the TA too
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by kamikaze2112
    Earlier I was contemplating removing the entire back seas and make a new amp rack there and incorporate my PC, thereby increasing my cargo room, but decided against it because I sometimes carry 2 passengers max.
    WORKLOG
    Webpage
    Newbie OKflyboy's Avatar
    Feb 2005
    Tulsa Area, OK
    Quote Originally Posted by Snootch
    You could always take out the bottom part of the driver's side rear seat since its never used. Then the carputer could go where the seat used to be... just a thought.
    Looking good so far!
    Feb 2005
    Barrie Ontario
    well, if my 'Fire ever becomes my toy and not a winter beater, the back seats will be comin out for sure.......
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    Hey, I have a TA too. What does your dash look like? What monitor and stuff. Your other work log shows "Bandwidth exceeded."
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
    Sep 2003
    Tampa, Florida
    Done a little more work, Currently I'm waiting for foam and epoxy to fully cure. Here are a few more pics:
    Carpeted the rack:
    I also made a small PVC plastic housing for my Powermate that will keep it looking smooth on what was the ashtray in the center console:
    Magnezium- I just got all the pics from the other worklog transitioned onto my new server. Post up if they are not working.
    WORKLOG
    Webpage
  1. USB 2.0 issues PLEASE HELP!
    By Kamakazie2 in forum General Hardware Discussion
    Last Post: 10-23-2006, 08:25 AM
  2. 2000 Pontiac Trans Am carputer install
    By Snootch in forum Worklogs
    Last Post: 02-10-2006, 01:18 PM
  3. 2000 Pontiac Sunfire, aka Geekfire
    By CavityCr33p in forum Show off your project
    Last Post: 01-19-2006, 10:29 PM
  4. pontiac sunfire 2000
    By Phantm in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2005, 10:00 PM
  5. FS: 99.5 (same as 2000) VW Jetta GL 2.0
    By sniz55 in forum Classified Archive
    Last Post: 02-14-2005, 05:31 PM
