Page 7 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 61 to 70 of 165
Thread: 2002 Mitsubishi Magna VR-X - 15.4" ultrabright LCD, fabricating...
  1. #61
    Oct 2004
    Sydney, Australia
    Quote Originally Posted by sporty_drew View Post
    looking very good, I see you've made some progress since i saw this on the fg forums. I've made my skin and am also finishing up a skin for a friend so i can give you a hand if you need it. I was thinking about making a portrait skin since i think I'm going to try what your doing
    This would be extra ordinary of you!!!
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
  2. #62
    Variable Bitrate portabuddy's Avatar
    Feb 2006
    mississauga, On.
    i have a 100 pack of 10mm 135000mcd white leds?, out of curocity what is the convertion from nits to mcd?, also what software did you use to convert your screen properly?
    Life Dosn't come with a reset button, if it did you might as well turn the game off.
  3. #63
    Oct 2004
    Sydney, Australia
    LEDs need resisters to go with, and pcb to solder/mount to. im pretty sure mcd is the same thing as nit. I chose to go many many smaller LEDs then a couple big ones for for better uniformed light.
    Via have released new drivers for there mobo vid cards that now support screen orientation, I downloaded and installed them. I then simply went to control panel>display>settings>advanced and it was in one of the tabs up top.
  4. #64
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Quote Originally Posted by portabuddy View Post
    i have a 100 pack of 10mm 135000mcd white leds?, out of curiosity what is the conversion from nits to mcd?, also what software did you use to convert your screen properly?
    1 nit = 1 CdM
    1 CdM = 1000 mCd
    1 CdM = the amount of light an average candle produces in one square meter.
    therefore, your 135,000 mCd led's are equal to 135 nits each.
    jsyk
    @biggy:
    1 inch = 25.4mm
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  5. #65
    Oct 2004
    Sydney, Australia
    oh, thanx for the info, that means mine are only 50nit each LED. I should never assume. Do you know how they measure nit, its it the rating of the ccfls added together? Or a measuring device on the panel itself?, I wouldnt mind testing my screen when its done. Yes I know its .4, I just rounded for simplicity.
  6. #66
    May 2007
    Lakehood, CO
    i'm not really sure how they measure it for a panel, pretty sure there's an photosensitive resistor involved, I just searched for the conersion rate, and found those values.
    I'd assume the total of all the led's would be pretty close to the final value of nits, but again it's just a guess.
  7. #67
    Oct 2004
    Sydney, Australia
    that means it will be 4000+ nits. The screen will prolly be a white blur at that brightness, gotta buy that dimmer. LEDs arrived today, pretty darn fast for overseas parcel time.
  8. #68
    Feb 2006
    mississauga, On.
    Quote Originally Posted by monkeyracer View Post
    1 nit = 1 CdM
    1 CdM = 1000 mCd
    jsyk
    @biggy:
    1 inch = 25.4mm
    AWSOME INFO, I got nothing with my search... I knew that mcd was milli candle power, but i didnt know that nits and CDM where the same, and no way that i will forget that in the future...
  9. #69
    Feb 2000
    hoppers crossing, victoria, australia
    some great work happenin in here
    where did you get the usb wifi card with antenna socket ?
    ive seen the ones on ebay and have read reports that there really crappy
    donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
  10. #70
    Oct 2004
    Sydney, Australia
    http://www.jefatech.com/product/WL-USB-RSMAP
    Ive got a friend using it now on his carputer and he has no complaints, he is also using that antenna.
