Page 1 of 17 1234567891011 ... LastLast
Results 1 to 10 of 165
Thread: 2002 Mitsubishi Magna VR-X - 15.4" ultrabright LCD, fabricating...
    Oct 2004
    Sydney, Australia
    ____________________________________________
    Thread Breakdown
    Original LCD fab starts at Page 1 - Post#11
    Original computer casing/mounting starts Page 2 - Post#23
    Sound starts Page 3 - Post#35
    LCD upgrade starts Page 3 - Post#40
    Fiberglass bezel work starts Page 4 - Post#46
    WiFi upgrade starts Page 4 - Post#53
    Skin work starts Page 4 - Post#57
    LED case fabrication starts Page 5 - Post#72
    Bezel molding starts Page 5 - Post#73
    The Car:
    After many hours of reading and thinking (and saving $$). Ive decided to start my carputer project. I live in Australia about 30 minutes drive north of Sydney. My car is an 02' model magna vr-x with a 3.5L V6 under the hood. This is an Australian made car.
    The Computer:
    Components:
    I was originally wanted to go with the new mini-itx Pentium 4 boards, but changed my mind because of the high power they use, the more heat they produce and the price. I didn’t need the crazy processing power anyway.
    VIA MII-12000 is the board for me, 1.2GHZ is plenty to run XP and a few apps. Inbuilt CPU means another component I don’t have to worry about. Board is 170x170mm, should fit nicely behind my dash. Purchased from a local dealer auspcmarkets.com.au for AU$302.50 delivered and is on its way.
    The screen was a hard choice, I wanted to get a Lilly manly for the support for it on these forums (like detailed tutorial on how to dismantle it), but my dash wouldn’t allow it. I only had 110mm tall gab to work with and the smallest lilliput was 125mm (I want the buttons). With my low knowledge of fabrication and experience in this sort of thing I decided to look for a smaller one with less modding. I found a 7"er on eBay by an Ex-Audio importer that will work. It is only 115mm tall which means I only have to cut 5mm to make it fit nicely. Also I like the buttons being on the right hand side close to the driver. 200:1 contrast and 400 nit brightness which is same as lilliput. This screen was AU$270 delivered from Hong Kong and is on its way.
    M2-ATX Power supply seams like the best option. Lots of power to play with, regulator and shutdown controller inbuilt. I always enjoy Plug and play, it’s the story of my life. I had a hard time trying to get this item within Australia. I ended up buying from eBay from an american dude, only US$9 shipping to AUS, not bad for an american postage price. Total prices AU$123 delivered and is on its way.
    Gear:
    I wrote out a shopping list and went to my local hardware store (Bunnings). I got a bunch of little things that ill need like soldering iron, solder, shrink wrap, dust mask, hot glue, tape, more dremal bits, sanding blocks ETC. For the fibo filler I bought somthing called Plasti-Bond. Comes with plenty of hardener and a nice big informative directions on the back. This tub was AU$50 and is 2Kg, amazingly it was only 2$ more then the 900g one. I had allot of brands to choose from, it was about second from the top in price. I also got some white primer, and some black paint, both aerosols. I got a little tube of bondo cream incase I need to touch anything up, prolly wont use it though.
    The screen will be fabricated into the double DIN spot of my car. The computer will squeeze in a flexiglass casing behind the screen (or so I hope). This mean the only cable coming out from the dash will be a USB for peripherals and sound. I found a spot to mount the computer case. But it mean I have to cut some metal out, which i dont mind doing.
    So the idea is to undo the bolts at the top, 2 each bar, then cut where i have marked. If I do this it will give me about a 300x200x200mm gab to work in, and will also give me a place to mount the case to those top bolts. Only worry is that the metal is supporting something that need that much strength. These bars are connected to so many different things down below, including the chassis, that I think it will be ok to cut them.
    Day 1:
    Received my mobo today, very nicely packaged and arrived within 30 hours of me placing the order. Included was an IDE cable, floppy cable, face plate, driver cd and instruction booklet. No mobo risers or screws, I have plenty of those anyway. Still waiting on the power supply and the TS, expected to take longer considering they are coming from out of Aus.
    A shot before I took the dash out completely, its 'loose' but gives you an idea what it looks like beforehand.
    Took the dash peace ill be working on completely out of the car today. Notice how little room there is to work with top and bottom, but some good space on the sides.
    For the hard drive and ram ill be buying locally. 512 RAM seams plenty for this motherboard. I haven’t decided which hard drive to go with. 2.5" is low power, but for the same price as an 80GB 2.5" I can get a 250GB 3.5". I have the spare power I think, but would the VIA bios recognise a 250GB? Would like to hear feedback on this one! Thanx for all your comments so far.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
    Dec 2005
    That vehicle isnt Aussie made... its the same as the American Diamante VR-X... just a differant bumper.
    Looks like a good project, the interior in those cars are pretty good looking, great for a carputer.
    ~Kris
    [1995 Nissan 240sx]
    Planning.........[::::::::::] 90%
    Parts.............[::::::::::] 60%
    Construction...[::::::::::] 10%
    Software........[::::::::::] 50%
    [1994 Mazda RX-7]
    Newbie OKflyboy's Avatar
    Feb 2005
    Tulsa Area, OK
    Good luck to you!
    I've seen that Ex-audio screen on ebay, I'm very curious to hear what you think of it when you get it.
    I am an American soldier. If you will not stand behind me, feel free to stand in front of me.
    Sep 2005
    Great post. Looking forward to seeing how it turns out.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i always liked the vr-x. Car had so much promise. To bad the engine wasnt up to par.
    Live mp3Car Facebook Chat
    Oct 2004
    Sydney, Australia
    Quote Originally Posted by Dopefish
    Mitsu Aust has been exporting Magnas/Veradas to the USA since the 2nd gen was introduced.
    Oct 2004
    Sydney, Australia
    Also to prove it I found an American car company eBay ad showing the manufactures label. Look at the last picture, the white label.
    http://cgi.ebay.com/ebaymotors/Mitsu...09298144QQrdZ1
    tja
    tja is offline
    Aug 2005
    sydney, australia
    cant wait to see more of this install
    2005 Nissan Xtrail
    DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
    worklog
    Dec 2005
    Quote Originally Posted by BiGGy
    Touche'
    Why that uglified the front-end in 2004 I dont know....
    ~Kris
    [1995 Nissan 240sx]
    [1994 Mazda RX-7]
    Oct 2004
    Sydney, Australia
    Touche'
    Yeah, I dont really like it either. Looks like a fake Kia front end.
