Results 1 to 10 of 12
Thread: 01 Honda Civic Sedan LX CarPC
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    Well my PC was installed successfully in my car for about two weeks. Then the boot times started to get to me, and the volume was not loud enough without significant interference/static.
    So, I pulled the PC and installed winXP, trimmed the boot time to about 30 secs, and changed the winxp boot symbol to a honda symbol (silver, matching my car). I bought a Bx55 (electronic 3 way x-over)
    Inputs/Outputs: front, rear and subwoofer
    Selectable crossover frequencies
    Subwoofer: 45Hz–4.2kHz
    Low pass (bandpass): 300Hz–4.6kHz
    Rear high pass: 65Hz–4.5kHz
    Front high pass: 65Hz–4.5kHz
    Variable bass boost, 0 – +18dB
    Slope rate: 12dB/octave
    Signal-to-noise ratio: > 110dB
    Remote subwoofer level control
    Lowpass input selector: Direct or front/rear mix
    Remote on/off power control
    Subwoofer phase switch
    (http://www.onlinecarstereo.com/CarAu...roductID=15879)
    These are a bunch of pictures of the PC / Case. It is a Micro ATX form factor desktop style case.
    The case has a custom top (hole cut, with a processor fan / grill in the top) moves alot of air.
    The fan speed is controlled on the back of the PC (the silver knob), this is neccesary since it gets REALLY loud.
    The Last image is a picture of the micro ATX case compared to a regular desktop style ATX case.
    REBUILDING!!
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    yikes! you gotta work on that bezel
    Aug 2004
    Haha yeah I know, it was my first real attempt at bondo'ing. I unfourtantely had to leave on a roadtrip right after i started bondoing/sanding, so I was unable to finish the sanding. I'll get around to fixing it though
    REBUILDING!!
    Aug 2004
    Here are some pictures which show the general progression of the fabrication of my lilliput monitor into my civic dash.
    This is the dash itself, dremeled to fit the lilliput housing:
    Anyways after getting it roughly fitted and very roughly sanded, i decided to work on getting the pc mounted in the trunk.
    I took some L brackets and bolted them into the side of my PC. Getting the holes in the pc took quite a bit of ingenuity (sitting for half an hour smashing the drill through the metal).
    REBUILDING!!
    Aug 2004
    I then started figuring out how to connect all of my USB devices. I ended up purchasing a 7 port powered hub (2.0), and a new pci usb 5 port card. As far as USB devices go, i've got a dvd burner, AyAy GPS mouse/card, bluetooth dongle, IR dongle, a numpad and a small backlit keyboard. I also will have various items powered (phone / bluetooth headset) and of course the lilliput usb touchscreen.
    REBUILDING!!
    Aug 2004
    As soon as the 3-way crossover comes, it will be reinstalled in my car, along with an a8000t (800/1600 watt abahn amp) and an alpine 4x50 watt amp. Anways feel free to critique/comment/ask questions.
    Edit: Forgot to mention the PC stats!
    It's a celeron 2.8ghz, 512mb Ram, 120gb HD, audigy 2. no optical drives. It is being powered by an Opus 150w. It runs Media Engine.
    REBUILDING!!
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by Escalade182
    otherwise things look good
    Aug 2004
    Thanks =) Any suggestions aside for fix my unfinished bezel?
    REBUILDING!!
    Aug 2004
    Serious alteractions:
    REBUILDING!!
    Mar 2005
    Maryland
    nice mods!
    those custom dents add a lot of character.
  1. 2006 Honda Civic LX
    By Wetzel in forum Worklogs
    Last Post: 04-07-2008, 11:44 PM
  2. Honda Civic 01 - Touchscreen Carputer
    By norek in forum Show off your project
    Last Post: 04-17-2006, 12:49 AM
  3. 2001 Honda Civic Sedan Carputer.
    By dannn in forum Show off your project
    Last Post: 08-10-2005, 07:17 PM
  4. 99 Honda Civic Sedan Screen Install
    By CustomZ02 in forum Fabrication
    Last Post: 10-07-2004, 10:13 PM
  5. 1993 Honda Civic LX
    By noodles in forum Show off your project
    Last Post: 08-18-2004, 01:28 PM
