Ah, you finally got it! I see you found a dash piece too. Suprisingly, as big and deep as the dash looks it really doesn't have much room behind it. I can post some pics for you. It is ridiculously easy to pop the whole dash apart (and put back together again). In case you haven't seen how. Remove the two screws on the panel under the steering wheel, pop that piece off. Then there is one screwe in the main dash piece around the steering wheel on the left side take that out, and the rest is pulling it off. Don't be skiddish, it takes some force, you just gotta lay em up there. Then pop the center dash out there are like 7 or 8 clips in all around it. Then you can do some realtime, 3D exploration.
How do you like the car?
LinkBack URL
About LinkBacks
and the dash looks very long and hollow(well,.. looks hollow) and i need to know if there is a spot big enough for a small full size or do i have to go with a full-fledged carputer, i have a relay strong converter that i got for free i was thinking of putting that in and running it off that, what do you guys think???
