OK I'm going to try and answer a bunch of questions here from both posts and personal messages that I received. This isn't directed at any one person and will hopefully answer everyone's questions:
1) The monitor is a modified 7" lilliput vga touchscreen. It is meant to fit a Suburu WRX but will fit cleanly in a 2005+ Mustang with the addition of the Metra double-din kit. You can find the monitor HERE.
2) Yes, these are VGA monitors, and are connected with VGA cables.
3) If you remove the stock headunit, you will need a 4-channel amplifier to power the 4 main speakers.
4) The speakers are connected through a Metra wiring kit. Yes, there are two Metra kits... a dash kit and a speaker wiring kit.
5) If you can't figure out my wiring diagram, then maybe this isn't the hobby for you, but I'll try to help. Sound is sent from the soundcard. My soundcard has three outputs: Front, Rear, and Center/Sub. These outputs are in 3.5mm form. So you need three stereo splitter cords that go from 3.5mm to RCA. The front and rear RCA's plug into your 4-channel amplifier. The Sub RCA plugs directly into the Metra wiring kit, which sends your sub signals to the stock amplifiers. Then you must use speaker wire to connect the 4-channel amp to the Metra wiring kit. Oh yeah, Metra stuff can be found at Crutchfield.com
6) If you are going to use a laptop, you better read up on inverters. Go to the FAQ Emporium and start researching.
7) The 12v to 5v regulator goes from your 12v ignition line to the "power on" or "trigger" lines for the stock amps (8" door subs) on the Metra wiring kit. Without it, you will get a popping sound everytime you switch on your ignition.
8) The Suburu kit is for the screen only. You can build a computer in the tight space behind the screen if you want but I built a seperate one and put it in the trunk.
LinkBack URL
About LinkBacks
