goodluck i always like to see pimped out minivans, if i was forced to get a minivan i would be forced to pimp it, its the only thing that justifies it for me (sry soccermoms 0l33l
We picked up our New 2006 Honda Odyssey LX last month and are well on the with the install (pictures to post in a week or so.
Heres my parts so far
1. Travla C158 Case with M1 Power Supply.
(120 gig WD Hard Drive ,512MB Ram, slot loading DVDROM/CDRW, 2nd PCI Video Card - see phase 2, winxpPro, Roadrunner, IGuidence)
2. USB Devices -
WintvUSB for TV and Radio, Wigi dongle, Bluetooth Dongle
4. Lilliput 8inch touch Screen (should have bought the 7 as tyhis is proving to be a tight fit - but i'll get it in there.
6. New AMP (arrives today so will post info tomorrow).
7. A Heap of wires and plugs.
PHASE 1
1. Decide where to mount the pc. DONE
There is an under floor compartment behind the front seats where the pc and amp and other junk fits perfectly.
2. Cathy , my techie wife , and I have sorted out how to remove the stock Radio / CD unit and I have Fabricated a new insert, around the lilli frame, out of Aluminum and Perspex. Cathy has covered this in a leather like material matching out seatcovers. - 90% done, just have to design one more attachment for securing it to the third and final chasis bolt hole, and extend the lilliput IR to side of screen as we have had to cut off the bottom of the lilli screen.
To Do
1. Run 2 lines from the battery through the firewall to the under floor compartment for the pc and amp power.
2. Use purchased breakout plug to extend speaker and areal lines from Radio location to underfloor pc location
3. Finnish pc software install - only iguidence left to install. winamp , RR and tinyxp on already.
4. test all before install and install.
PHASE 2
The second part is to install a second roof mounter display for the kids to view the movies we are currently converting to Divx. This display will run off the second video card in the pc concurrently with the gps software (we hope.)
Also will add OBDII connection to pc
I Have pictures going up now on my CarPC Blog.
http://kiwicarpc.blogspot.com/
The PC is built and Im beginning the install into the Van. I hjave a little more on the dash insert to do but the end it in sight.
Heres the pc
And this is the das h insert with cut down lcd frame (8inch lilli )
And the completed vent and wiring holes in floor of van - leading to underfloor compartment. I may cut one more to keep power wires away from speaker wiring.
2006 Honda Odyssey
Lilliput 7inch touchscreen
Travla C158 case
VIA SP13000, 512mb ddr, 110Gb Hard Drive
802.11B, Bluetooth, Wintvusb
IG 3,01 NA
Roadrunner
A mile of wires and a ton of solder and a prayer or two.
My workspace and work area with the PC in various stages of building
2006 Honda Odyssey
Travla C158 case
IG 3,01 NA
Roadrunner
Some More pics
2006 Honda Odyssey
Travla C158 case
IG 3,01 NA
Roadrunner
More photos -
The indash replacement part we made is constructed out of perspex and aluminum and covered with a leather like cover cathy put on the front of it.
2006 Honda Odyssey
Travla C158 case
IG 3,01 NA
Roadrunner
more pics of the work in the Van. The 2006 odyssey has a under floor compartment behind the front seats, ideal for the car pc to be. I drilled a fan hole for ventilation and also a wiring hole in the non moving plastic part of the door so if I messed it up, I could just buy a replacement door.
2006 Honda Odyssey
Travla C158 case
IG 3,01 NA
Roadrunner
I have the Ir Extended now and two screens working.
The 8inch Lilliput I have seems fuzzy and out of focus - Im working to try to figure out why.
More pictures soon
2006 Honda Odyssey
Travla C158 case
IG 3,01 NA
Roadrunner
I have two power runs from the battery , through the firewall, to the carpc location done. Also the Ground runs to a suitable location.
Will run the rest of the cabling this week and get the install finnished before the end of the month with pics also.
2006 Honda Odyssey
Travla C158 case
IG 3,01 NA
Roadrunner
disaster struck as we were putting in the lcd.
A little too much force and it cracked and broke :-(>.......
oh well, ordered a slightly smaller 7inch lcdand it arrived today.
will install it and the pc on saturday, snap pics and poct next week.
2006 Honda Odyssey
Travla C158 case
IG 3,01 NA
Roadrunner
