Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: SRCSTC's New Carputer Worklog - 00 BMW E46 323Ci
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    Arrow SRCSTC's New Carputer Worklog - 00 BMW E46 323Ci
    Current List of Parts:
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    some nice stuff your using there. How much is everything costing you?
    _
    Mar 2004
    Little Elm, Texas
    @ cj8501: couldn't you just go in and add it all up yourself?
    @ srcstc: what are your plans for all of this equipment? I see you're selling some other equipment? from an old install? change of plans?
    Jan Bennett
    Dec 2003
    New Jersey
    More Pics...
    Variable Bitrate DaveB's Avatar
    Mar 2004
    SRCSTC,
    From your choice of hardware its obvious that you know what you're doing. You made excellent selections. I do wonder why you chose such a small and slow hardrive? Have you considered getting a larger capacity, higher spindle speed, SATA hardrive? With disk being so cheap these days you may as well get a drive with at least 200 GIG.
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Dec 2003
    New Jersey
    Quote Originally Posted by DaveB
    SRCSTC,
    I chose it for it's size. I wanted a low-power notebook drive. It does have an 8Mb buffer.
    Mar 2004
    Ah...okay, I see you're using the 120 watt Opus. I'm using the 160 watt M2-ATX. Power wasn't so much of a concern for me with that PSU. I opted to go with a 300 GIG SATA drive.
    Just in case you haven't put your PC together yet, I can let you know that Intel has a more current driver available for the 915GM chipset which gives a lot better resolution options than the driver that ships with the CD that comes with the motherboard. The Lilli TS driver needed to be updated, too.
    I have most of the drivers needed to get everything working correctly. If you're still in the process of building the PC and are interested in the drivers let me know and I'll post them for you.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Tainted Love Cris's Avatar
    Romania
    When will it be ready?
    Dec 2003
    New Jersey
    Thanks for the tip! This it?
    http://downloadfinder.intel.com/scri...ional&lang=eng
    Dec 2003
    New Jersey
    Quote Originally Posted by Cris
    It is.
  1. Carputer Slowing down BMW E46..gork??..srcstc??
    By badandy4you in forum Power Supplies
    Last Post: 10-13-2006, 06:37 PM
  2. 2001 BMW E39 - fully integrated Carputer
    By tsingsu in forum Show off your project
    Last Post: 05-03-2006, 05:51 PM
  3. obd for bmw e46
    By vl20sas in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-08-2006, 11:36 AM
  4. Worklog: Wasabi's 2001 VW GTI VR6 Carputer
    By Wasabi in forum General Hardware Discussion
    Last Post: 10-08-2005, 02:11 PM
  5. Opus and BMW (e46)
    By captain_jim1 in forum Power Supplies
    Last Post: 01-21-2005, 12:46 AM
