Results 1 to 9 of 9
Thread: 2004 Nissan Sentra
    Feb 2006
    Boulder
    Cool 2004 Nissan Sentra
    Last month, I bought myself my first carputer from mp3car.com- an Ampie case with an M10000 board, 512MB of RAM, a 60GB hard drive, bluetooth, and a M2-ATX power supply inside, plus a 7" Lilliput touchscreen. So far it's just been sitting on my desk while I configure software.
    Last week, I decided to get started on putting it in my car. First project- getting the screen in my dash. My biggest requirement for this project is that the screen must not be visible from the outside while the car is parked- I don't want to just hang a 7" 'STEAL ME' sign in my car. My '04 Nissan Sentra has a funny little compartment on top in the center of the dash that looks like it's just perfect for a screen, and I was rather inspired by Tony N's install.
    Fortunately, as an enginnering student at the University of Colorado in Boulder, I'm in close proximity to the greatest hardware store ever, and I have access to both a full machine shop and a pair of laser cutters .
    Well, after a week of wandering around the hardware store looking thoughtful, buying four kinds of hingest, four kinds of glue, a sweet little butane torch, and more bits and pieces than I care to count, cutting myself twice, ruining several pieces (two drilled too big, two cut too short, one melted), and swearing a lot about there being half an inch too little space in several directions... I have a prototype!
    I say prototype because many of the parts are imperfect or made out of cardboard and duct tape. I'm pretty confident that with a few hours in the machine shop when I get the time, I can make a pretty slick final version of this.
    I made a backing for my screen with 1/4" acrylic (I may try 1/8", if I find it's strong enough) by laser-cutting out the shape I want, then using my new butane torch to carefully bend it in two places. Then I tapped an unused screw hole on the top of one of those vents to take a small length of threaded rod, which the aluminum rods slipped onto. On the bottom of the backing is a pair hinged-on plastic things that can slide back and forth on the rods. On the top of the backing is a hinge fastening it to the lid. There's piece in the back (currently cardboard, planned to be acrylic) holding the back of the rods in place.
    One day, I want to motorize this thing. No plan on that at the moment.. that will come after everything is installed, but I have some ideas.
    _
    Mar 2004
    Little Elm, Texas
    very creative!
    is there a plan to maybe integrate the screen in a bit more?
    Maybe a shroud to where you think it's not a screen propped in there but rather a screen that's part of the lid?
    Jan Bennett
    Newbie EvilAngel's Avatar
    May 2005
    Merida, Mexico
    Interesting, since i might get a sentra i was looking for the exact same thing. I just believe that if you reinstall the lid button it might cover a bit of the screen.
    I checked b15sentra.net and some people have done it with smaller screens but never with a 7''. Anyway, keep the good work, you're quite ingeniuos.
    Edit: And one more thing, don't you think that the screen might be a little too far for the touchscreen to be practical? I've put my touchscreen in the bin of a sentra and i feel it's a bit far for reaching it while driving. Of course, i'm a bit short too. And you might want to chech chillboy and gizaks installs, but scpecially tony n's since he was also making a hideaway. Just in case you hadn't already, that is...
    El Volcho is in progress...
    Got almost everything
    -Via EPIA M10000, Super 7'' Touchscreen, Morex Cubid 3677 Case, Fujitsu 40Gb, 512DDR RAM, Sony DVD-CDRW...
    Planning 80%
    Parts 60%
    Building 40%
    Oct 2005
    Montville, NJ
    any updates???
    Feb 2006
    Boulder
    Sorry, haven't made a whole lot of progress. I laser cut and bent up some acrylic to replace the cardboard in the picture, but that's about it. The screen is a bit harder to move in and out than I hoped, so I want to motorize it now.
    Unfortunately, the end of school and now the beginning of work has been keeping me busy, but I really want to get some more progress done on this soon.
    Motorizing the screen isn't looking to be a simple project.. I need to select a motor (thinking about a servo modified for continuous rotation), work out the drive mechanism (thinking about a long screw drive or a simple belt drive), then build a circuit to control it all.
    May 2005
    Merida, Mexico
    For the cheapo/do it yourself minded (like me) you could use an old cdrom drive mechanism... At least that's what i think..
    Planning 80%
    Parts 60%
    Building 40%
    Feb 2006
    Boulder
    Update!
    Unfortunately, motorizing the screen turned out to be a much bigger headache than I first anticipated. I looked into four and eventually tried two different ways of doing it, and they all had very significant problems. I finally got tired of my computer collecting dust while I futz around with the screen mount, so last weekend I decided to just get the screen and computer installed and working, and then work on fancier features later.
    I wrapped the screen backing I made in gaffer's tape (greatest tape EVER) to eliminate a squeak, ran all the cables behind the stereo and under the armrest to the computer, which I put under the driver's seat. I have to open the screen by hand (poor me), but it's not too bad.
    Now I need to mount a USB hub to plug stuff into, find better input devices, and get the software just how I like it (can't wait for Centrafuse to be released...), and make a simple mixer for the line in jack (ATM it's pulled behind the face, plugged straight into the computer).
    Newbie Yacob's Avatar
    Nov 2006
    Connecticut
    very nice. my mom actualy want to put a 7" monitor in her sentra that flips up in that compartment.
    To the world you may be one person. But to one person you may be the world.
    Newbie Omoikane's Avatar
    Sep 2006
    Great job, gives me a few good ideas
  1. Carputer in 2002 Nissan Sentra questions
    By jnye6625 in forum Newbie
    Last Post: 06-22-2009, 02:14 PM
  2. 05 Nissan Sentra
    By Tony N. in forum Worklogs
    Last Post: 01-05-2006, 03:52 PM
  3. FS: 00-03 Nissan Sentra Blue Tinted Tail Lights
    By migel628 in forum Classified Archive
    Last Post: 06-13-2005, 06:02 PM
  4. Replies: 9
    Last Post: 06-06-2005, 12:28 AM
