I ve been exploring the trunk today.
First is first:
Cut the electricity totally before the installation by unplugging the battery ground (brown cable).
There is a dark point;
1. I have two batteries. One in the trunk and one in the engine. Am i supposed to unplug both of them or just one in the trunk.
First think i am going to do is remove cd changer and use the socket for my carpc. That socket includes all the cables i need, ignition, 12v batt, ibus, ground and amp remote port (i seems so lemme know if it is not).
After that operation my pc will work after i connect my M2Atx and Car2PC adaptor.
Second operation is removing the HU.
I will remove the business casette and put my 7" tft screen in double din without the housing. It is supposed to fit. I'll leave the radio but put it behind the dash. Probably there will be also a socket with necessary connections for my screen and second PSU(acc +12V, -12V via HU). As you see my case contains also a psu (62W) which is gonna be used for the screen.
There are still three dark points at this step;
1. If i remove the radio how am i supposed to switch between pc and radio that are used to be managed by radio unit? I really didn't get this part.
2. There are some buttons under my screen. I don't know if i can put them somewhere else.
3. Will just a parallel ignition 12V connection from HU to screens psu be enough?
After my screen is ready to be powered up i will connect pc to my screen.
For this step i'll need 1 usb cable for Touchscreen, 1 VGA for my screen, one cable to the driver side headrest for microphone, one audio/video extension cable for the tv tuner later.
After this step my carpc is supposed to work.
Any opinion or silly question will be greatly appreciated...![]()
LinkBack URL
About LinkBacks
don't drink and drive
Just put in dc-dc
I am still waiting for some technic assistance of my brother.
