Results 1 to 6 of 6
Thread: 1998 Cadillac Deville Concours
    Variable Bitrate quantum's Avatar
    Sep 2005
    After about 6 months of planning, strategizing, reading, and researching on this forum, I have finally begun my installation. I put my first car stereo in my dad's pickup truck when i was 12, which was 25 years ago. Countless cars later, and an underlying urge to totally have cool electroincs in my ride, i have finally found the one that is deserving of a CarPC, a 1998 Cadillac Concours DeVille with 300HP Northstar, 65k miles, and totally mint inside and out. of course, there is also that Caddy ride...sweet. The last pic shows what I am attempting to do with the TS in the dash, via photoshop.
    I think the most important start to a project of this magnitude is the planning stages. Thinking through potential problems and overcoming them with desired results. Like I said, I have been collecting drawings and ideas floating around in my head for a long time, and am just now getting started.
    Also, I would like to do this so I can return the car back to factory stock if need be. Lastly, I work in the highest car-theft city in the US. Thankfully, only 2 days a week, but still...I'd like it to look from the outside like just another nice car, no goodies inside.
    The computer, part 1:
    One major problem I found dissapointing was a good PC solution for radio, but I understand there are some in the works.
    One major problem with this car (which I found out in a caddy forum) is removal of the factory head unit, which is exactly what i want to do. Evidently, things like retained accessory power and door chimes are routed though the head unit and factory steering wheel controls , and if removed, the car don't know what to do. So, the first hurdle was, how do I get the best of both worlds? Especially retaining the steering wheel controls.
    Natural answer was to relocate the headunit (trunk), and since I will be fabricating a custom carpeted PC case, I incorporated that into the design.
    Next question, how do I get 100% of the data from the factory harness in the dash to the plug in the back of the stereo in the trunk? I would need to run an extension cable, pin for pin, from point A to point B. The problem is most of the Metra and other units only give you the speaker, power/acc and ground wires, which leaves out half the pins. (32 pin plug, 23 wires needed).
    So, thanks to a $12.00 CD-ROM for http://1ezwire.com I found the pin selections, and started thinking about the harness. Not to sidetrack, but I did contact installer.com, and although the folks there were very very helpful, I was told there were no real options, and no one would build me ONE custom relocation harness...now if I wanted 100 of them...
    I would up going to a local stereo shop, bought 2 male harnesses and pulled enough wires from one and put them in the other, matching pin for pin. I also bought the factory 32 pin female harness, which comes with about 27 pins wired. Now, all I need to do is extend it wire for wire, about 20 ft (read: s**tloads of splicing) and voila, a relocation harness for 15 bucks in parts and about the same in wire.
    Another interesting thing about this car (and many others too, more than you think), it is wired from the assembly plant with a 10 pin disc changer plug in the trunk. There are a few adapters that let you convert this to an RCA audio in, I found the one by PAC (Aux-Box and GM-10 cable) http://www.pac-audio.com/ was an easier set up than the PIE hardware http://www.logjamelectronics.com/piegm10aux.html. The PAC stuff was plug and play, the PIE wasn't.
    Now, with this rig in the trunk, the PC and factory stereo in the trunk, and the option of being able to run sound from an 1/8 inch jack to a pair of RCA's...you guessed it, EVERYTHING runs through the factory amplified sound system, just like that, with a couple of plugs.
    This solution gives me:
    Factory AM/FM Radio
    An auxillary input source (or sources with a splitter) into the factory system for the PC sound card out jack.
    All the bells and whistles that are wired into the car and Class2 data bus.
    The ability to adjust the volume and radio station presets from the steering wheel, without seeing the headunit.
    The next problem this creates is how do I switch between AM, FM, and "CD-Changer" if the radio is in the trunk? I pulled apart a scrap radio I got on e-bay, and it is simply a board mounted mini push button switch. I think this can be de-soldered and relocated with a length of wire back into the cabin, but that is going to take a little experimenting.
    So far, I have all the parts for the PC:
    Converted desktop MOBO with AMD 2500+ processor
    512 megs of RAM
    2.5" 60 GIG Toshiba Laptop Drive
    Promate 7" TS kit (more details on that REAL soon!)
    Thin USB keyboard
    DSATX Power Supply (the best purchase I ever made)
    USB / Firewire / Serial / Ports and 5 PCI slots
    RoadRunner Front End
    Delorme Streets and Trips with USB GPS for rear window
    Wireless card
    So, I have the parts to get started, a little here, a little there, and connectors everywhere (the guy and Radio Shack is going to be the godfather to my next kid:
    Yesterday, I ran an actual test in the car, with the DSATX and all the stuff just laying in the trunk,and it works!! Wooo hoooooooooooo!!!
    Now, little by little, it will find a permamnet home in the Cadillac.
    Off to play, stay tuned!
    Oct 2006
    Caddi forum
    I have a 1999 Cadillac Deville that I would like to put a carputer in. I have been told from the local audio shop guys that I will need to relocate the stock radio to the trunk as you have mentioned. I just ordered the CD-ROM from 1ezwire.com. Thanks for the link. If you could reply with the link you found in the caddi forum about the stock radio replacement it would be much appreciated. I have the column shift version of the deville and was wondering if it will be different then yours. Im not looking to have any audio run through the stock radio. I just want all the chimes, alarm functions, and starting of the vehicle to still work. Looking forward to any updates/pictures of your progress. Good Luck!
    Sep 2005
    Hey HopeSlayer,
    Do a search at cadillacforums.com for tons of info on the relocation of the stock radio. Not sure where the link was, but you'll see it in there. It is a pretty hot topic.
    I preferred running the PC through the factory system, this way there would be no fuss about using just the chimes, just the alarm, etc. I weighed both options, and finally decided to build the longest splice in my life, wire for wire. Reason being is at that point, even if you didn't want to use the sound system, it would still be hooked up completely.
    They also make bypasses and work arounds for aftermarket headunits, I believe PAC audio hasd them as well.
    Good luck, pics coming one day!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    just a quick observation, the scale of that screen looks to be too large in that comp that you had done. I'd say it will fit within the real estate that the buttons occupy, but wont go out further then that.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Oct 2009
    Sorry man but that's a total photoshop or MSpaint edit.
    Sep 2005
    Uhhhh, yeah...
    This was my worklog, (planning, photoshop, mockups, etc). The lcd pic in this thread was just to see if the scale was correct for the monitor.
    That project was 100% completed, car sold, and the link to the new install is in my sig.
    Oh, and ty for the honor of making your first post an observation of my worklog.
  1. Cadillac SUV has Shuttle XPC inside
    By TheScream in forum General Hardware Discussion
    Last Post: 12-03-2003, 09:26 PM
