Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 81 to 90 of 103
Thread: Zebel 2001 BMW 330ci Carputer
  1. #81
    Nov 2006
    Quote Originally Posted by Zebel View Post
    I am using map monkey although iGuuidance is much more accurate but the iDrive Skin I am using works better with MapMonkey, I may be wrong it may be an easy tweak to make iDrive work with iGuidance.
    If you want to use MapMonkey or FreeDrive then you must use the Destinator. The Destonator SDK consists of only one unlock version of "DestDll.DLL" file. You could buy it or google for it, I am sure you would find it on some Torrents site. You can buy Destinator maps for North America from Amazon.com just for "Destinator Map for North America". it costs $100 to $130.
    ok thanks.. looks like i will be using Mappoint because i foudn one for a cheap price.. quick question, since i will be using mappoint.. under the GPS settings in RR, i would check the mappoint option, and where it asks for map monkey path and gps path, do i just leave those blank ?? and basically just enter the GPS Comm port (comm 7 in my situation) correct ??
    thanks..
    -Steph'
  2. #82
    Low Bitrate Zebel's Avatar
    Apr 2006
    Quote Originally Posted by CoupeE46 View Post
    thanks..
    -Steph'
    Leave those blank, Also put 0 for GPS port. You shoud have assigned GPS port within MapPoint. What version of MapPoint are you using? The latest RR is compile with MapPoint 2006 and if you have earlier version of MP it may not work unless you run an older version of RR that was built for that version of MapPoint.
  3. #83
    Nov 2006
    2006 .. thanks ok, so everything blank except ticking the mappoint option .. thanks..
  4. #84
    Feb 2004
    To the Killer:
    Here is how I powered up the PC with 12V switched line:
    I tapped into the switched 12V from the radio's harness. I connected the BMW Metra harness to the OEM radio harness. Then I looped 12v Red with Blue to power antenna and HK amp. Do not confuse this blue with the other blue remote wire coming out of OPUS PS.
    I also tapped into the same 12 V wire coming and extended it all the way to the trunk to the PC.
    and a pic to help you out:
    Hi zebel,
    I'm also trying to connect my pc with a sven 4 to my bmw stock amp (i think it's not an hk amp because I only have 10 speakers in the car).
    For now I have no sound, and I see in your picture that you have looped the blue wire to the 12v. Do I have to do this too, to make the amp and the sven4 and the pc working ?
  5. #85
    Apr 2006
    If you have HK amp then you would have the "Harmon Kardon" sign and wirting by the speaker next to the door handles. You will also see the subwoofer in the trunk under the rear deck.
    The reason I looped the blue wire was to turn on the amp. I am not sure what kind of amp you would have on non-HK upgrades. Try the same thing I did and loop the blue and red see if you get sound. Good Luck!
  6. #86
    Feb 2004
    Thanks for the answer. I've no Hk sign and no subwoofer but I'm sure that I've an amp
    I'll try to loop the and red tomorrow (it's time to go to bed in France).
    Thanks for the help
  7. #87
    Feb 2004
    I follow your instructions and it works I have sound in the car now.
    Thanks again.
    The sound is not very loud because I don't have the soundgate and I don't know where to buy this in France.
    I wanted to know if you can give me a link to download the RR skin you use (no the Idrive but the other) ?
  8. #88
    Apr 2006
    Sweet! I am glad it worked.
    You can download the latest rr along with any skins you want from here
  9. #89
    Feb 2004
    Very good link, thanks !
  10. #90
    Feb 2004
    I don't have chance, the file downloaded is corrupted
  1. My Aussie Car PC System
    By vxcarpc in forum Show off your project
    Last Post: 10-17-2007, 06:12 PM
  2. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 10:11 AM
  3. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 05:30 AM
  4. 2001 BMW M5 MP3 project
    By cjones in forum Show off your project
    Last Post: 09-30-2003, 11:47 PM
  5. New toys for the pc car
    By gizmomkr in forum General Hardware Discussion
    Last Post: 02-06-2002, 04:55 PM
