Results 1 to 10 of 19
Thread: 2002 Jetta
    Newbie DriverFound's Avatar
    Jul 2005
    Colorado
    Lindsey's Install, 2006 - 2002 VW Jetta 1.8T
    I'd like to thank the site for providing all sorts of helpful information to a first-timer like me.
    Inspiration for the layout: ppgt94 (ID on here... awesome work)
    First, Take the car apart (almost... slight exaggeration) to get the center console out.
    I took the zenarc apart and cut the edges down a little so the case fit like this:
    I started off working with fiberglass, and it went smoothly until I started sanding and the fiberglass lifted off... So I started over with bondo.
    I've never worked with any of this stuff before so it was definitely a learning experience.
    Here's some of the bondo progress (and yes, I learned I should have made it smoother when it was still wet...later):
    Here's the sanding progress... The goal was to keep the line in the xenarc casing so it wouldn't be completely flat... I thought it would look nice to keep some of the lines. Sanding goes on for two weekends... sanding it down with 400, 800 and 1600 grit... then the sandable primer with wet sanding.
    Here's adding more bondo to the middle 'cause it wasn't flat:
    Here's how much bondo got under my nails! My gloves were too big, so I didn't use them all the time...
    I can't find the rest of the sanding pics, but basically, I sanded A LOT. Then my friend Greg (the perfectionist) took over with primer (used a can of sandable primer), wet sanding, painting and wet sanding and gave it back to me looking like this:
    I put the screen itself back in and also the slimline DVD (I don't think there are pics above of this, but I'll add more pics later... I cut out a slot for the DVD drive).
    So I am off to start installing the console back in the Jetta and running wires to the trunk.
    And, if you are interested, here's a pic of my car (with my friend, Eugene doing something to his camera):
    Variable Bitrate nitropwd's Avatar
    Sep 2003
    bloomington,mn / moss point,ms
    Wow....very nice job on the Bezel fabrication
    Motherboard: Epox MATX
    Power: M2-ATX
    Storage: 120gb 3.5"
    Optical: Slim Slot cdrw/dvd
    Audio: SB Audigy 2
    GPS: BU-353 & iGuidance 4
    OS: Win FLP (Fundamentals)
    Frontend: Roadrunner (DFX 3 & 4)
    Jul 2005
    Colorado
    Thanks!
    BTW, the problem I'm currently working on is how to go from the laptop DVD drive to USB. Originally my plan was to use a 10 ft round IDE cable... use the adaptor from 40 pin to IDE then run the IDE cable back to the trunk (well that doesn't exist). So now I'm looking for laptop DVD drive to USB. I've seen it somewhat explained in here, but I honestly just don't see it.
    Do I need to get the adaptor to go to IDE from the laptop DVD drive and then an IDE to USB adaptor? And, do all IDE to USB adaptors require a separate power source?
    Newbie 4MYFAST's Avatar
    May 2006
    SoCal
    Bezel looks sic, grats!
    This should fix your notebook dvd problem:
    http://www.mp3car.com/store/product_...products_id=92
    06 GTI MKV
    Car Info, Pics, and Mod List
    Carputer Progress
    Planning
    [== 12% ]
    Parts
    [= 0% ]
    Testing
    [= 0% ]
    Install
    [= 0% ]
    Variable Bitrate madkad's Avatar
    Jul 2005
    uk
    WOW nice job I love the look that makes me wish I bought the Jetta I was looking at a while ago
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
    Constant Bitrate ZtH01's Avatar
    Jan 2006
    Mankato, MN
    Quote Originally Posted by 4MYFAST
    I use that one too. Use firewire if you can. It'll save you a lot of headaches with bootup. And, you won't need a seperate power souce.
    ...No IDE connection required...
    -ZtH01
    Jul 2005
    Colorado
    Sweeeeet, thanks for the suggestion - I've been searching these threads all day for what others did.
    Thanks for the "looks good too" this is gonna be awesome.
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    Looking nice. Thats gonna look completely stock once its in the car.
    Civiputer: Dont have one anymore, but here is what is used to be!
    Mar 2006
    I really like how that turned out. You did a great job at showing the step-by-step processes through the pics.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    looks really good!
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. What's with the sudden flood of newbs?
    By ShinkunoNamida in forum Off Topic
    Last Post: 03-29-2007, 02:43 PM
  2. 2001 VW Jetta
    By mccdeuce in forum Worklogs
    Last Post: 01-17-2006, 07:27 AM
  3. Rims for 2002 jetta
    By dragon_fire3k in forum General MP3Car Discussion
    Last Post: 12-16-2005, 10:24 AM
  4. 2002 1.8T Jetta Carputer NEWBIE!!
    By hockmastr8 in forum Newbie
    Last Post: 07-09-2004, 10:08 AM
  5. Digital 2k2 Jetta
    By ppgt94 in forum Show off your project
    Last Post: 02-20-2003, 03:42 PM
