+ Reply to Thread
Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 60
Thread: 2001 Mustang
  1. #11
    _
    Mar 2004
    Little Elm, Texas
    watch for water collecting on the inside of the spoiler. would have to seal it off 100% otherwise you will run into big issues.
    Jan Bennett
  2. #12
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by cliffloehr
    FM will be routed to the original antenna on the car's front fender. All the remaining antennas (AM, GPS and WiFi) will be routed into the trunk and through the trunk lid, into the leg of the spoiler, and up into the spoiler itself. I was thinking of cutting an access panel in the bottom of the spoiler and mounting them all on the inside.
    You should get the cobra r spoiler (3 piece) if ur gonna do this...it will be easy to gain access to the inside of it and it looks sweet. Costly, but if ur gonna do that, u should do a complete conversion and either go for the cobra r front or the cervinis stalker front and sides (i had that on my previous car along with the kaminari rear and nothing beat that look).
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  3. #13
    Registered User cliffloehr's Avatar
    May 2006
    Decatur, AL
    Quote Originally Posted by 3onDubs
    cobra r spoiler
    I'm sure your right... but I have a problem adding flashy-type upgrades. Maybe it's because I saw a guy once who put all the Cobra ground effects, wheel hubs, and badging on his V6 mustang and did nothing to the engine. I did install official GT fog lights, dual exhaust, and GT MAG rims... but I'm avoiding all the "look" only type upgrades.
  4. #14
    Raw Wave tj!2k4's Avatar
    Oct 2004
    If I'm not mistaken you've got a fiberglass trunk and hood, just like my 03.
    From my experience, XM and GPS work perfectly through the fiberglass, so those you can mount to the inside of the trunk lid.
    Dunno about the AM and WiFi, but give it a shot.
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    I'm sure your right... but I hate people who try and make their V6 mustangs look like Cobras! I did install official GT fog lights, add dual exhaust, and GT MAG rims... but I'm avoiding all the ground effects and "look" only type upgrades.
    A MEN!
    That's one of the biggest posur moves a person can do.
    also, Sat. rad. works from beneath cowls, etc. had a sat rad ant. installed under the plastic cowl of the truck for something like 7 years and it worked perfectly fine.
    Jan Bennett
  6. #16
    May 2006
    Decatur, AL
    Quote Originally Posted by tj!2k4
    Yes the 01' is the same, you bring up an excellent point, and I should start inside the trunk and move to the spoiler if I have any reception problems. No since making more work or myself.
  7. #17
    May 2006
    Decatur, AL
    Quote Originally Posted by Red GTi VR6
    fab works looks to be good, at least from the shots provided!congrats!
    I went out of my way to hide imperfections from the camera!
    Red, your work is insanely impressive - Hat's off to you!
  8. #18
    May 2006
    Decatur, AL
    This is a bracket to hold the Computer in place. It was welded together then welded into the car to wrap around the AC controls. The top rail is the original rail and welded back into the same location... (maybe I was too gun-ho in the demolition phase).
    Because the Car Computer is the same size as the original radio, I was able to use the original mounting hardware.
  9. #19
    _
    Mar 2004
    Little Elm, Texas
    very nice!
    Jan Bennett
  10. #20
    May 2006
    Decatur, AL
    So Far...
    Hear is the (assembled) PC setting on the bracket... it is very stable and easily slides in and out (Like the original radio)
    NOTE:
    A fan is mounted top/center on the case and draws air in from both sides of the DVD drive (under the motherboard) There is an 1/8 gap all the way around the motherboard allowing fresh air rise through the case, over all the components, and out the top. The car's air duct (above the case) is angled perfectly to deflect the air, exiting the computer, to blow on the back of the LCD screen.
+ Reply to Thread
  1. 1987 Mustang GT Convertible MP3 Mustang
    By jzgt in forum Worklogs
    Last Post: 10-26-2007, 09:18 PM
  2. Front end with Autoroute 2001
    By Davefocus in forum Software & Software Development
    Last Post: 06-26-2005, 06:01 AM
  3. FS: '93 Mustang GT Immaculate!!! **MUST SEE**
    By Loco in forum Classified Archive
    Last Post: 06-16-2005, 10:22 AM
  4. WTB/FS: Alot of things. Mustang parts/Computer
    By SilverGT in forum Classified Archive
    Last Post: 03-15-2005, 12:38 AM
