Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 60
Thread: 2001 Mustang
  1. #21
    Registered User cliffloehr's Avatar
    May 2006
    Decatur, AL
    You can make more room for the extra wires coming out the back of the PC by:
    1. Cut the two plastic anchors
    2. Remove the bracket (on the left side) and reinstall it, in front of the wire harness.
    This gave me more then an inch of more space behind the PC.
  2. #22
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Looking good.. can't wait to see that finished. I like the relocated defrost/fog/traction buttons and a/c.
    You mounted your case (along with the fan) the same way I did... turned out great for me. Good luck
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  3. #23
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by cliffloehr
    Great tip!
  4. #24
    May 2006
    Decatur, AL
    The Screen
    The screen came in today. It's an 8" 16:9 touchscreen (Provision PRTV805VT) off ebay The screen is thinner then most of the 7" screens and and has no odd shaped edges... all straight and square making it much easier to install. However... I made the stupid hole in the bezel too small and have to rework the whole thing. I also made the PC sit up too high and need to rework the mounting bracket.
    Anyway, the screen is such a good fit and the extra inch makes a big difference! I'm SURE their will be more of you switching to this screen!!!
    LESSON LEARNED:
    Don't customize the bezel until ALL the components come in!
    WARNING:
    #1 While the screen is awesome! It is not with out some quirks! The VGA cable will not reach the back of the PC... and it is the wrong sex to plug directly into the computer anyway! It comes with a 6' extension, but I only need another 3 inches... (but thats another story)
    #2 The screen had a bad connection (the red pin was not firing) after moving some wires around, I found the bad spot... it was inside the screen!
    Since the connection was bad and the VGA cable needed a sex change operation anyway... I voided my warranty and copped it off!
    #3 Two of the connectors (power and VGA) plug into jacks (inside the screen) that are the wrong size!!! The VGA uses 6 wires and has a 6 pin connector... but plugs into an 8 pin jack mounted on the main board! The power jack is the same way. I thought I'd never get the thing working again!
    I finally did get it in the car for a silent run (no sound - just power) all is good (The screen fits and looks SO nice... I'll post some photos tomorrow.
  5. #25
    Constant Bitrate racerx3165's Avatar
    Sep 2005
    McConnell AFB Wichita Ks.
    I've been planning my CarPC for about 2 months and have already purchased all the hardware. Speciman inspired the design approach with his 94 Mustang. I'm in the process fabricating the case and hacking up my dashboard right now and thought it would be good to start a work log. The plan is to place the entire PC inside he dash where the radio was.
    Hahahaha and i still havent got mine done I need to get busy and find some money. Anyone have a money tree lying arond i can buy? Looks great man im hoping this will get me back at it...
    Cars
    1994 Mustang GT Punch 240.4 2 12" Kicker Comp SOLD :(
    2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
    2003 Eddie Bauer Expedition DVD - Navigation Package Traded in for 2008 XL-7 Limited
    Car PC
    Planning
  6. #26
    Oct 2004
    When I saw the opening for the bezel's opening for the screen, I suspected that you were going with an 8", so I checked out the link to the screen you posted.
    One of the things that would be of concern with that screen is the brightness of only 125 cd/m², especially when compared to the Xenarc's display brightness (w/ Touchscreen) of ~300 cd/m². From my experience in the coupe, the Xenarc leaves much to be desired in the way of visibility in the sunlight.
    I realize that you are recessing the screen as far as possible, but even so
    I'd be very much concerned about how that particular 8" will pan out in a vert..
    Edit: Interesting.. the first link you provided to the amamax.com site shows the brightness as 125
    cd/m².. the eBay link shows the brightness as 350 cd/m2.. which is it now..? lol
  7. #27
    May 2006
    Decatur, AL
    Quote Originally Posted by tj!2k4
    The manufacturer's website said brightness=350 and contrast=350 so I was not worried. After receiving the unit, the manual also agrees... Also, I was driving around today and it is fine. Of course on a sunny day, with the top down, any screen would wash out. In addition to recessing it in as far as I can, I was thinking of mounting it so it can tilt up-n-down.
    With the top down, it reflects whatever is directly behind me.
    After rebuilding the VGA connector inside the screen, I've been having some flickering problems today. So this evening I've been in-n-out of the screen several times trying to improve the connections... at the moment it won't get power at all. I'm so freaking mad about those stinking connectors being the wrong size! Why would a company do that in a "moble device"?!?
    Quote Originally Posted by racerx3165
    I've been pushing myself to finish. Actually I've had the VIA M10000 for over two years! I gave up on trying to build a MythTV (Tivo thingy) I've decided I am NOT a Linux man! So I eBay'ed most of the parts to convert the project to a car PC... I'm glad I did. if I can ever get the screen to work!
  8. #28
    Sep 2005
    Well i got the power wire ran in my Suzuki and most of my time has been spent on that car but i still plan on doing the Mustang PC for sure...
    Cars
    Car PC
    Planning
  9. #29
    May 2006
    Decatur, AL
    After trying to fit it all together, I've determined the gap between the A/C controls and the DVD needs to be smaller. So I'll be redoing the mounting bracket when I return home.
  10. #30
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    Nice Job..... It's looking great!!!!
    It's soooo nice to see more Stangs around here!
    CHEERS!!!
    Willy
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
  1. 1987 Mustang GT Convertible MP3 Mustang
    By jzgt in forum Worklogs
    Last Post: 10-26-2007, 09:18 PM
  2. Front end with Autoroute 2001
    By Davefocus in forum Software & Software Development
    Last Post: 06-26-2005, 06:01 AM
  3. FS: '93 Mustang GT Immaculate!!! **MUST SEE**
    By Loco in forum Classified Archive
    Last Post: 06-16-2005, 10:22 AM
  4. WTB/FS: Alot of things. Mustang parts/Computer
    By SilverGT in forum Classified Archive
    Last Post: 03-15-2005, 12:38 AM
