this vehicle has a climate controlled glovebox, I would not see a need to drill any holes.
I was only half serious that you'd have it done by June 24When you figure out the speaker / amp situation, I'm interested in what you're gonna do about that. Also, did you plan on running FM/AM radio or some form of Sat radio? Or is it just MP3s?
Edit: Just re-read first post...saw you're going XM. So you're eliminating FM/AM altogether, right?
current system: car2pc adapter playing aux in for a sansa fuze media player. simple. cheap. effective.
I am sorting out the audio part as we speak (type). I found a user on the audiworld forums that has a good write up on replacing the factory stereo with an aftermarket in his 2003 A4 avant. Looks like I need 1 4-channel amp at the minimum. I'll have all the details of the audio in my worklog as I move forward. I will not be using AM or FM for now, and XM will come later. For now, stage 1 is just mp3 and cd for music.
@Paul H - It is the symphony double din radio. It has a 6 disc in-dash changer.
~Puff
View my worklog... I dare you... http://www.mp3car.com/vbulletin/worklogs/77267-2003-audi-a4-worklog-puffs-ride.html
Carputer Progress [||------------------] 10%
Update:
Here is the diagram for my system. I'm going to add it to the OP too. I know the audio stuff needs to be figured out still, but how does the rest look?
EDIT: This diagram gets updated as I figure stuff out...
~Puff
View my worklog... I dare you... http://www.mp3car.com/vbulletin/showthread.php?t=77267
How are you powering that amp?
Don't forget the fuses.
Still looking good.
ODYSSEY
All information expressed in this post is my opinion, and should not be regarded as a statement of fact.Digital-Car UK|
(\__/)
(")_(")
Diagram updated. I'm not sure where the fuse goes, is this right?
~Puff
that fine for the main fuse, but I suggest you us a distro block after that. Check out my faq on wiring an opus, its the same principle.Originally Posted by Puffanug
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Yeah, distro block. Have one main fuse, then a distro block with individual fuses.
ODYSSEY
(\__/)
(")_(")
~Puff
There are two types of installs and in those installs you have several levels.@Paul H - It is the symphony double din radio. It has a 6 disc in-dash changer.
The main differense is that the normal (cheapest one) has 2 front speakers in the door and wired directly to the radio output and each level up has more speakers and options, like active speakers
The bose system has a amp. instead of direct radio output.
The radios are the same but they are programmed with the bose option so the internal amp(in the radio) is off.
if you have a Bose system it's diplayed on the radio when you turn it on and it's on the door panel.
Paul Huijgens
Audi technician
former Saab technician
Mp3Car.com Forum
SaabCentral forum
Dutch Carputer forum
Navplus forum
