Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Kia Spectra 2002 with Xenarc, please help me out guys...
  1. #11
    Mar 2006
    hmm, here is a first layer of bondo, I think I epoxy too much or something, and now I can see the bondo and the epoxy mix. How do I fix this problem thanks.
  2. #12
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    mine mixed and i had no problem with it...if u sand correctly u should be fine...u can always add MORE bondo if needed.
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
  3. #13
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Couple ideas for the future. Duramix 4058 works awsome for bonding plastics and filling holes. Sands good also. I also like Rage Gold over Bondo. Sands smoother and has less pinholes. Also to make your life easier shape the bondo with a razor blade when it is still soft. Save a lot of sanding down the road.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
  4. #14
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    80 grit. sand sand sand snad sand sand. then take some more bondo and fill in the low spots. then sand and sand and sand, untill everythings level and flat. sand down, build up the low spot, sand some more. I had somewhere around 40 hours of sanding before it was about perfect befor i took it to the shop to be sprayed. it doesnt look perfect overnight, but be patient, you dont wanna go this far and then when everythings 90% done rush and have it look like crap. since its your work, and its going to be in your car, youll see every flaw in it.
    dont worry man there is a light at the end of the tunnel. looks good so far at any rate. keep up the good work.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  5. #15
    Mar 2006
    spent like few hours to add bondo and sand, now I got this, I think I really need more sanding, I will need you guys help me for paint.
  6. #16
    Mar 2006
    any suggestion for this guys ?
  7. #17
    May 2006
    Texas
    wow looks good, I had to make sure it was your's. I am indeed impressed.
  8. #18
    Jun 2006
    Looks great!
    I have the same car and a few questions. Would it be possible to move the rear defrost and the hazard light switches to the empty slots behind the steering wheel? Ditch the clock? I figure if I can then maybe there would be enough room for an 8 inch monitor and keep my bottom din cubby or use it for input, slimline dvd and usb. Though that ashtray looks like it'd be perfect for plugging in usb things.
    How much room is there behind the dash?
    My project is still in it's wish list stages with only a few things like XM on the decided list.
    I'd love to see some in car shots of that thing. Looks awesome!
  1. What's with the sudden flood of newbs?
    By ShinkunoNamida in forum Off Topic
    Last Post: 03-29-2007, 01:43 PM
  2. Replies: 4
    Last Post: 05-15-2006, 08:59 AM
  3. Epia MII 1200 and Xenarc = No signal
    By badandy in forum LCD/Display
    Last Post: 08-29-2005, 04:52 PM
  4. 2002 Kia Majentis 2.5 Automatic
    By 2funk in forum Worklogs
    Last Post: 06-22-2005, 05:04 PM
  5. Xenarc 7" Touchscreen VGA Group Buy.
    By Skippman in forum LCD/Display
    Last Post: 07-27-2002, 10:52 AM
