Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 2003 S10, first install
  1. #11
    Mar 2004
    Little Elm, Texas
    just because you can't find a solution, doesn't mean you use a bandaid - there's something else going on behind the scenes that you must not be seeing.
    Jan Bennett
  2. #12
    Variable Bitrate portabuddy's Avatar
    Feb 2006
    mississauga, On.
    i have nearly the same mobo, and similar setup and mine runs at about 20-30*C or 70-85*F and thats playing movies, mp3 and downloading 24h a day. there has to be a sereus problem with your setup, i recomend re-installing windows. anthen going from there...
    Life Dosn't come with a reset button, if it did you might as well turn the game off.
  3. #13
    Constant Bitrate stealinfool's Avatar
    Dec 2005
    The mobo isn't overheating. It's the controller for the LCD display.
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 03:41 PM
  2. 2003 Toyota Matrix install
    By Matrix_24 in forum Fabrication
    Last Post: 05-16-2006, 07:01 PM
  3. Can I use nlite on an existing install?
    By omehegan in forum WinNT Based
    Last Post: 07-08-2005, 04:33 AM
  4. Lcd and Ps2 install in 2003 WRX
    By WRichieX in forum Newbie
    Last Post: 03-10-2004, 09:37 PM
  5. M10000 install - 2003 Mazda 6
    By Litespeed in forum Show off your project
    Last Post: 03-08-2004, 09:45 PM
