I was hoping it was in Visio !! Not to worry mate, i'll start a fresh.
I am in the process of mounting mine in the boot. With all of my install it was important not to add ANY holes to the car. I found a way of mounting a panel in the boot of the vehicle behind the seats.
It uses 4 bolts in total, if you need further instructions of how i did it, send me an email and i'll send more detailed instructions.
Heres a quick shot so far - http://www.wrx-carpc.co.uk/Photos/sl...0Mount%202.JPG
Next step is to get it covered in the same fabric as the rest of the boot. It will be a good sized mounting platform for all the CarPc components. Also less tempting to be stolen or kicked if its under a seat. This way all the components, PSU, CarPC, USB Hubs etc can all be neatly mounted next to each other on one easily removeable panel.
Regards,
Steve
LinkBack URL
About LinkBacks
I was going to use Visio latest version but couldn't find a copy, so I had nothing to do, pretty much, and went to do it in photoshop. You can still do it if you like, and then use image map areas to link to vendors if you like.
I didn't know I had to modify my panel (see attached) it doesn't fit vertically, so probably I'll spend tomorrow night trimming it. Anyone else got bumped like this?
