So, as the installation/configuration is now underway, some modifications had to be made.
1. The fabricated dash insert for the single din radio had the hole cut in it that wasn't quite the right width for the screen. So, I went to CarToys, purchased some basic install plastic and black vinyl. After cutting out the right size hole, I wrapped the black vinyl around the plastic and through the hole to "smooth the edges". This insert was glued to some small pieces of wood, which I then screwed into the plastic on the back of the removable portion of my dashboard console.
More modifications/progress to follow...
LinkBack URL
About LinkBacks
