Page 1 of 6 123456 LastLast
Results 1 to 10 of 53
Thread: Bimmerpc BMW 320 -02 touring CAR-PC project
    Nov 2005
    Current planning schedule! Suggestions or thoughts are exteremely welcome!
    I started from original picture from Puffanug
    2003 Audi A4 Worklog ~ Puff's Ride
    hope You do´n´t mind!
    I customized it to my needs. Most of the products that will be used is in my hands or are shipped.
    But I am completely flexible to sell things back on ebay if someone convince me I should do
    Nov 2005
    Current comments/issues
    I greyed out one power lead (from the usb hub that will be available within reach so I can insert portable devices. Not sure I need it to be powered?
    Not sure either that I will need the other one to be powered
    Not sure if Wifi plug delievers enough reception if it´s hiddein with the other things
    My IBM notebook doesnt seem to have usb 2.0 because windows displays that I am currently attaching a highspeed device to a low speed usb connector.
    Is usb 2.0 very important for some of my devices or can I just run everything with 1.0/1.1 ?
    Elsewhere
    The USB hub is something you're going to have to experiment with. Some devices need a powered hub. Some don't.
    The more physical layers between the WiFi adapter and the device it's connected to, the worse your reception will be. The best solution is to use a 2.4Ghz WiFi antenna outside the vehicle.
    The three things in your diagram that I see that you'll want USB 2.0 for are the optical drive, the bluetooth and the WiFi. I'd think the TV adapter would be better off w/ USB2.0 as well, although I don't know.
    As a general rule, TV in the car sucks balls. Reception is marginal at best. I suggest leaving this as the last thing you implement for that reason. Chances are if you don't have TV in your ride, you're not going to miss it.
    How about the Wiki?
    Nov 2005
    Talking
    but what are the options on doing an upgrade to my notebook? is there a usb 2.0 pcmcia card
    Tv is just for "parked car" situations. I recall that I saw some kind of H-shaped in-car antenna maybe hide-able inside car panels. (Hirschman maybe?)
    The small antenna I got gave good reception yesterday when I did hold it a with my hand outside my window and on top of roof
    Imagine best possible reception look of my car
    Usb radioshark antenna on roof
    Wifi antenna on roof
    Tv-antenna on roof
    gps antenna on roof
    will look like I´m working for BBC news or something when driving
    Black SolarCell Portable Bluetooth Gps reciever for sale, Contact me!
    BMW E46 320 Touring project thread, making the perfect multimedia car ;)
    BMW E46 WORKLOG
    Jan 2006
    for powering your laptop poke around here
    http://www.atbatt.com/laptop-batteri...inkPad_A31.asp
    i think this one may work for you
    http://www.atbatt.com/product/7593.asp
    I got one for my inspiron 5100 and it works like a charm and its much more efficent then going to an inverter. It takes about 10 amps so I found a 30 amp relay that Im going to use with it.
    98 V6 Camry XLE
    Status-Everything is working again!
    No progress while I am in NYC
    Ze Worklog
    Elsewhere
    Quote Originally Posted by bimmerpc
    They exist.
    Tv-antenna on roof
    gps antenna on roof
    Not if you get one of these: http://www.mp3car.com/store/product_...roducts_id=148
    That covers GPS & WiFi and cellphone as well.
    How about the Wiki?
    Nov 2005
    Quote Originally Posted by Anshu
    ok, but is there any easy instal in car for "non car products" like the laptop?
    I mean some kind of box that I attatch to the car powerline and that has got standard power connectors so that I can just use any product and plug their included power adapter to that box?
    BMW E46 WORKLOG
    Nov 2005
    Quote Originally Posted by DarquePervert
    They exist.
    Yeah thanks, I saw one at ebay, looke neat! so I guess that is the way to go unless there arent any replacement parts so I can put it inside my docking station which is the one I am planning on attaching the usb chain to.
    BMW E46 WORKLOG
    Jan 2006
    yes, what that is an inverter. they have quite a few downsides, so many people choose against them.
    98 V6 Camry XLE
    Ze Worklog
    Nov 2005
    Any way, do someone know a way to check weather or not my pc has got usb 1.0 or 2.0?
    BMW E46 WORKLOG
  1. PC wont boot while car runs
    By Empreez in forum Power Supplies
    Last Post: 11-30-2005, 05:25 AM
  2. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  3. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  4. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
  5. New toys for the pc car
    By gizmomkr in forum General Hardware Discussion
    Last Post: 02-06-2002, 05:55 PM
