Page 1 of 7 1234567 LastLast
Results 1 to 10 of 65
Thread: The Land Yacht - not so kludge Sprinter install Rev3
    Constant Bitrate TheLandYacht's Avatar
    Oct 2005
    Austin, TX
    Pre-Planning stages.
    To take the existing setup (Monstrosity #2) and consolidate down using a server case I managed to get my hands on. So. Step1, Pics & Measurements.
    The dimensions of the server case are
    Depth: 21"
    Width: 16.5"
    Height: 26"
    Here are some pics.
    Pics, measurements, & diagrams of the inside of The Yacht for pre-planning forthcoming
    Oct 2005
    Austin, TX
    And more pics
    Oct 2005
    Austin, TX
    OK. Time for more information. Here is a rough sketch of the interior of the van, AS IT IS NOW.
    On to more stuff.
    The inverter, which will hopefully be mounted inside the above case is 9.5" long x 8" wide x 3.75" high.
    There are also various power strips that will live inside the case, and a video splitter box.
    For outside the case (possible ideas are false floor, etc), I'll need to mount 2 amps and a "Air Conditioner Control Board" (basically a very simple circuit board that controls the rear-top mounted air conditioner).
    Right NOW, ALLLLLLLL of these things, including the computer, are mounted inside Monstrosity.
    Amp1 (subamp) is 12" x 7.25" x 2.5"
    Amp2 (mainamp) is 10.5 x 11.5 x 2"
    Forgot to measure the "AC Control Board". Will get that later.
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    ...I think I'm missing something... why you using a server case?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Oct 2005
    Austin, TX
    And a rough sketch of the new layout with the new Server Case in the van.
    The Server Case will probably sit on some sort of pedestal or false floor, about 5" high.
    Oct 2005
    Austin, TX
    And the concept for the false floor and the stuff that will live under it...
    Oct 2005
    Austin, TX
    Quote Originally Posted by Dennis5587
    My setup is rather more sizeable than the average setup.
    Low Bitrate S11D336B's Avatar
    Feb 2005
    Florida
    Looks like he's packing everything including audio amplifiers into the box. That'll be sweet when it's done.
    ________________________________________________
    Worklog
    K7VTA3
    1500+ Athlon 4 Mobile
    510mb PC3200 DDR
    ATI Radeon 7000 64mb
    [||||||||||] 95% Complete
    RentATechnow.com
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    That's a nice looking server case as well.
    Failure is not an option....
    It's installed by default on every version of Windows.
    Elsewhere
    This is in a Dodge Sprinter van that's a taxicab. Space certainly isn't an issue for this case.
    You also haven't seen the specs for this man's CabPC...
    This freak of nature has an Athlon64 system with 2.2terabytes of storage for videos, mp3s, movies and whatever else he's got in there. There are also four screens, one of which is a touchscreen for passengers to select videos.
    Space is an issue with the current Monstrosity. That's why the swap.
    How about the Wiki?
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. XC90 Install - am I the first??
    By klokman in forum Worklogs
    Last Post: 02-13-2007, 01:12 AM
  3. 94 Jeep Grand Cherokee Install
    By jamiewhittingha in forum Show off your project
    Last Post: 08-02-2006, 02:02 PM
  4. '99 Mercedes Sprinter Install Progress
    By DTACK in forum Worklogs
    Last Post: 10-03-2005, 07:55 PM
  5. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
