Results 1 to 10 of 17
Thread: Holden Commodore VSII Carputer
    Jun 2006
    Sydney, Australia
    Hi everyone. I've been reading the forums for a little while and have decided to do my own carputer.
    First, the car....
    Holden Commodore VS series II (1996 model)
    3.8L V6
    LOL Car's pretty dirty at the moment. Raining a fair bit here in Sydney recently so it just picks up dirt each time it gets driven
    This is where i plan on installing the screen. I'm going to remove the Sony Headunit, cut out the plastic buttons where the ABS/SRS label is and fabricate the screen in there and the carputer will be mounted in the glovebox.
    The Carputer:
    - VIA M10000
    - M2-ATX PS
    - 512mb RAM
    - Seagate 80Gb hard drive
    - Compaq notebook DVD-ROM
    - Lilliput 7" TS
    - Windows XP Pro
    - Probably Frodoplayer as the frontend
    - Slimline notebook IDE adapter
    - Diagnostic cable to connect to ECU
    I think thats everything. Everything is ordered except for the Lilliput, should all be arriving in the next few days. I'm on Uni holidays for a month at the end of next week so it will be full steam ahead from then.
    I've gotta say a huge thanks to everyone on the forums at Mp3car.com I've built computers before, but never anything for a car. I've been able to get all the information i need from these forums.
    I'll update as the build progresses
    Newbie cppp's Avatar
    Jun 2006
    wollongong, australia
    Hey there. Im in almost the exact same boat as you
    I to own a Holden VS and I’m going to be putting a carputer in these holidays aswell.
    Im just waiting on the screen to arrive and I need to buy a power supply.
    Ill be mounting my screen a little different to you though, ill have mine sitting above the abs/irs and antenna controls.
    Although ill be keeping a close eye on your project especially how you do the wiring and dash removal stuff.
    Also are you running the sound from the computer to the HU or running it straight from the computer to amp/speakers?
    Good luck with it anyways
    Let the world roll along... Ill catch up later.
    Mar 2006
    San Diego, CA
    I saw this title and thought someone was putting a Commodore 64 in their car! LOL, crazy Aussie's!!!
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/worklogs/77267-2003-audi-a4-worklog-puffs-ride.html
    Carputer Progress [||------------------] 10%
    Jun 2006
    I thought the same thing.
    Jun 2006
    Sydney, Australia
    lol @ commodore 64 hahahaha
    Hey cppp.....Yeah i plan on running the sound from the computer to the H/U. I wanted to still be able to listen to the radio so i'm going to mount it in the glovebox and get my mate (electrical engineer) to extend the wires to the faceplate so i can mount it on the dash.
    Jun 2006
    Sydney, Australia
    Just a quick update.....
    The M10000, M2-ATX and Hard Drive all arrived. There are a couple of pictures below showing the mounting of the mobo and PS. I've basically just screwed some standoffs into a piece of MDF that is shaped to fit the floor of my glovebox
    Now im just waiting for the RAM and dvd-drive to arrive so that i can start loading up the software
    Jun 2006
    Sydney, Australia
    Another Update
    First day of uni holidays
    Basically ripped the dash apart and got stuck into the wiring.....what a painful process!!!!!! Every dash component seems to be connected to about 5 other parts that all need to be removed as well
    Anyway eventually got it apart and ran the power wires for both the carputer and the amp through the firewall.
    Lots of wires!!!!!!!
    Also relocated the Headunit....I originally planned for it to go in the glovebox but room does not allow for both it and the carputer so I've mounted it under the passenger seat, with the aim of remotely mounting the faceplate on the dash somewhere.
    Still waiting for the RAM to arrive, but i've got plenty of stuff to keep me busy in the mean time
    The screen and the DVD-drive also arrived today so i can start fabricating the screen surround. Below is a quick mock-up of where the screen and dvd will be mounted.
    Via M10000, 512mb RAM, 80Gb Seagate HD, Lilliput 7" TS, M2-ATX, Tray-load DVD-ROM
    Jun 2006
    Sydney, Australia
    More Updates
    Well, everything has finally arrived over the past two days. I spent yesterday loading the OS etc on my very sophisticated workbench (see below)
    Today, i basically spent the whole day applying bondo, then sanding, then bondo, then sanding etc...... It was my first time using bondo, and you can see from the pictures that i used waaaayyyy too much at first Thankfully, the electric sander quickly cut it down to size lol. I've applied one coat of paint, but as i suspected, all the small imperfections have shown up so i'm going to keep filling/sanding until i can get rid of them.
    Also, i originally planned on mounting the DVD underneath the screen, but space (or lack thereof) means that i'll have to mount it in the glovebox with the rest of the carputer.
    After the first series of bondo/sanding
    Round 2 .........
    More filling
    1st coat of paint....lots of small imperfections to be fixed
    Still plenty of work to be done....as of now nothing is actually in the car at the moment, apart from the wiring.
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    i hope you didnt use bondo as a "glue" to hold the lilliput casing to the dash bezel because it will crack. Bondo is a filler only ....
    Dash needs a little more work, but other than that looking good...
    Jun 2006
    Sydney, Australia
    na didn't use bondo as a glue. The lilliput casing was epoxy-welded to the dash before the bondo was applied
  1. Holden commodore 3.8 V6
    By Hammo in forum Classified Archive
    Last Post: 11-26-2006, 11:30 PM
  2. Holden VS Commodore Carputer Finished
    By XtremeX in forum Show off your project
    Last Post: 12-22-2005, 04:19 PM
  3. Holden VS Commodore
    By goatess in forum Show off your project
    Last Post: 12-21-2005, 11:32 PM
  4. Replies: 3
    Last Post: 03-30-2005, 06:15 AM
  5. Holden VL Commodore -> MP3IAN MkII
    By MP3IAN by Ian Gregory in forum Show off your project
    Last Post: 11-09-2002, 10:46 PM
