Results 21 to 30 of 31
Thread: 2006 G35 Install - First one
  1. #21
    Jun 2006
    Ventura County
    I think that I will adjust the position of the Pandora since it is pushed back a little from the opening. I want to reduce the amount of space by as much as possible since the pre-cut version of the din-cover is slightly wider than the Pandora.
  2. #22
    Jan 2007
    Smile
    hi. I'm just about to install my Car PC and I do not understand about the ground wire of Carnetix P1900. Where should I install these ground wires ?? I want to know exactly the place so that I can wire it and can you tell me about the ignition wire... where it is??
    My car is 2005 G35 coupe.. Thanks
  3. #23
    _
    Mar 2004
    Little Elm, Texas
    The ground wire is just connected to the car. Just like you would ground any wire in a car.
    The ignition, well, I'll leave that up to the OP...since I'm not familiar with that car and where it's easiest to pick up an iginition source.
    Jan Bennett
  4. #24
    Jun 2006
    Ventura County
    All you really need is a switched power source. I simply tapped into the cigarette lighter line for that. For the ground wire, I connected it to the fender wall inside the engine compartment.
  5. #25
    _
    Mar 2004
    Little Elm, Texas
    really should ground to the factory ground if at all possible if you're already in the engine compartment...fewer ground points is better.
    Jan Bennett
  6. #26
    Jun 2006
    Ventura County
    It's been a while since I've actually looked under the hood, but I think I actually used one of the existing ground points. I don't remember off hand though...
  7. #27
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    install is done eh? any final pics?
  8. #28
    DIGItonium
    Guest
    Very nice! The computer I built is for the 2008 G Coupe. From the sedan, I notice the glovebox is much bigger and more roomy. I'm still not quite sure how I'm going to fit my system, but it'll involve lots of cutting Hahah.
    I just hope it doesn't come with that integrated computer stuff like the '07 Sedan... I don't know how people are going to be able to install an aftermarket system.
  9. #29
    Jan 2007
    Thanks a lot. You guys help me a lot.....
  10. #30
    Jun 2006
    Ventura County
    Thanks!!! I worked hard on getting it put together properly. I'll take some new pics. I DO think that I am having some power problems on the external drive though. Every once in a while something happens causing either a drop in power or something where the power supplied to the external drive causes the drive to disconnect. This is causing a "Delayed Write Failure" so to fix it I have to unplug the drive, and plug it back in after a few seconds. Kind of a pain...
  1. I want to install a switch
    By Froogle in forum Power Supplies
    Last Post: 04-13-2006, 11:12 PM
  2. Replies: 1
    Last Post: 01-10-2006, 05:00 PM
  3. windows xp install
    By Moneyfink in forum WinNT Based
    Last Post: 03-09-2005, 01:05 AM
  4. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
  5. Infiniti G35, 7" Xenarc Install, How-To Doc
    By god_of_cpu in forum LCD/Display
    Last Post: 02-20-2004, 03:03 PM
