2006 G35 Install - First one
Well, I figured that I'd introduce myself and get going on this install! I'm ready to take the AOpen Pandora plunge.
Car Specs
G35 Coupe
Sport Suspension
Premium Package
Aero Package
After reading through countless posts I've come up with the following as my shopping list.
Hardware
- Aopen Pandora Here
- Xenarc 700TS w G35 Housing Here
- 40GB HDD
- Celeron M 340 1.5 ghz
- Carnetix P1900 Here
- 512 MB Ram
- Carnetix CNXP5V for Monitor Here
- Aopen MiniPC plug-and-play cable kit for P1900 Here
- G35 Single Din Converter Here
- G35 Ashtray Insert -Not sure if I need this or not
- BU-353 GPS Adapter Here
- AAI-NIS2 - Still need to order...
Software
- Windows XP Home
- StreetDeck Here
Additional Pieces not yet Figured out
Cam for rear/front view display.
UPDATES
7/31
Well, after a couple of months worth of planning, and a good solid week of my car being torn apart, I have everything installed and working properly...
I ordered a bluetooth dongle, Wireless USB dongle, webcam, plus a couple of extra cables that I thought that I might need. I'm going to install the webcam to point to the backseat so I can see my passengers while driving. That will happen this week.
I suppose that I'll start a new thread for my completed set up!
7/24
The extra cables that I picked up from eBay didnt do the trick...got a little frustrated...so I decided to cut the main cables and use quick connectors for everything so I could remove the cables and plug the cable back into the power brick for testing. I ordered the AUX input adapter today so hopefully I'll get it in the next couple of days. They are in SoCal so it should be here in the next few days. I need to set up the switch still, so that will take extra time, but this week looks like the week for the final install...I keep forgetting to post the pics so I'll do that soon...
My boot up time is still in the 45 second range so I;m thinking about using the pulse reature of the P1900 and hook it up to the turn signals since they fire up with the alarm. Either that or the door locks since that would activate as soon as I open up my door so by the time I get in and situated, the system will be fully up and running. Either that or leave the system in standby...havent decided yet.
7/20
Borrowed a 20A bench power supply from a friends dad...and voila! Connected everything up...well, I connected the Pandora to the wall power supply, the touchscreen to the P1900 power supply, the AOpen button kit to the pandora and the P1900 to the bench supply. Turned on the power, then connected the ignition line to the power and everything powered on.
The computer powered on first, then the screen and USP hub powered on a few seconds later. FYI, the Xenarc plug fits the Pandora so I picked this up on eBay...well, it was a 4 pack designed for a cctv system, but the connections are the same. I cut off most of the lead since all I really wanted was the barrel connector with a few inches of lead wire so I wouldn't have to solder or cut my main wires. Didn't notice it before but my driver CD for the Xenarc got cracked during shipping so I had to download the drivers from Xenarc. I'll post some more pics tomorrow...
http://i29.photobucket.com/albums/c2...r/23031032.jpg
7/17
I am more of a reader of the forums than a poster so that's why i haven't been updating my worklog! Anyway, I put solderless quick connects on everything to get it tested.
http://s180397741.onlinehome.us/CarPC/Picture 904.jpg
I was also thinking about removing the extra cables like the extra power cable using a molex plug remover. I would rather remove the extra stuff than leave it hanging out.
http://s180397741.onlinehome.us/CarPC/Picture 908.jpg
I'm using some PC cord wrap that looks like chinese handcuffs. It expands as you compress it. I thought it looked better than tie-wrap.
Here is the power supply I picked up along with the digital milti-meter I'm using to test voltage
http://s180397741.onlinehome.us/CarPC/Picture 906.jpg
http://s180397741.onlinehome.us/CarPC/Picture 907.jpg
7/12
Well, I got my order in yesterday...damn UPS GROUND!!! I should have done overnight...oh well...
Took a bunch of pics and I'll post soon, but since I have a lot of the same stuff as everybody else, I'll just post the pics that are different I suppose.
First thoughts...
- at first I was a bit overwhelmed after unpacking everything...with all of the hardward and wiring, but after I took each component and looked at it as different pieces of the puzzle instead of the entire package as a whole it was easier to digest.
- The single din converter is a little flimsy so it bent a little during shipping but that was expected I suppse....
- Damn that pandora is tiny...
- The G35 700TSV screen kit looks great overall but since the two sides are only supported at the bottom they bent out easily during shipping so the screen came out when I took it out of the box fairly easily. This shouldn't be a problem once I get everything installed since it will be supported on the sides. I think I am going to make some improvements to the slide area since the movement is not as smooth as it could be. Overall a well made product.
I ended up going to Fry's to pick up some installation supplies...wire stripper, connectors, that sort of thing. I also picked up a 12v power supply so that I can bench test everything before I install it. I want to get everything totally planned out and semi-prewired before I even touch the car so I don't spend the entire weekend with it apart trying to figure out what I am doing or where I am going to place something. :rock:
I know it won't be perfect, but planning always helps right???
7/4
I'm not sure if I need to get the ashtray insert. I was thinking of getting a blank piece of sheetmetal and adding in a couple of USB ports as well as possibly a switch to reset the system if it freezes up. Can anybody tell me if the switch kit for the P1900 disables the front switch on the Pandora? I'm thinking about doing something like this in the ashtray area...
http://images.andale.com/f2/127/100/...t_panel_03.jpg
I only want a couple of USB ports and possibly a switch to reset the whole system if it freezes up on me.
7/2
Ordered Everything!
6/30
This is going to be used for GPS/NAV,mp3, movies, possibly B/T integration, internet browsing (while parked of course), Traffic, and weather. I'm not going to use this for games or anything processor intensive so I think 1.5 should be more than enough.
I haven't bought anything yet, but this is my basic list of what I'm planning on picking up. I saw another thread about using an audio mixer to play both Carputer and head unit at the same time.
I'll post pics as I start to get stuff in but I wanted to get an idea on what you all thought of this set up.
I'm sure that once I get going with it, I'll be adding new things as time goes on.
