Results 1 to 4 of 4
Thread: Peugeot 206 Carputer Install Project
    Jun 2006
    Hi,
    I was told about these forums by a friend and have been amazed by the idea ever since, So...
    I am hoping to purchase a M10000 Mobo with a Cubid Case with the M1 ATX with 2X 2CH Sony Xplode Amps. I have had to make many converters and install many cables to make it possible for it to all work properly.
    My first post will include the Speaker Looms and Harness Converter and a basic diagram of what I’m trying to achieve.
    Please tell me what you think i would like your input!!
    Basic Wireing Diagram
    Harness Adapter Convertion
    Insead of cutting my stanard ISO block connector i have brought a female to male connector and just cut it down and soldered it to the Molex block as you can see.
    Speaker Looms
    These will split a 8 core cable down to seprate cores for ease, inclusive of the adapter is a RMT connection which is introduced by the M1 ATX PSU (Anti Thump)
    Picture of the Actual Car...
    Jun 2006
    Progress of the Project;
    Car-Ice Project Buying List
    o Small Form PC Case
    o MX1 PSU
    o M10000 Mobo
    o 512 Ram
    o 60GB High RPM HD
    o DVD Drive Laptop Style
    o DVD RW USB (for glovebox)
    o Sony Xplode 2CH Amp 200Watt a Side X2
    o TFT VGA Motorised Monitor
    o USB GPS/W Software
    o USB Bluetooth Adapter
    IIC Project Equipment Purchased so fare
    - Harness Adapter
    - Connectors
    - Cable
    - USB FM Radio
    - USB Cables
    - USB Hubs
    - SVGA Cable
    - Coxal Cable
    - USB HDTV DVB Tuner
    - 5DB Wifi Magnetic Antenna
    - 2M RP-SMA Cable
    - Phono (RCA) To Jack
    - Soldering Iron
    - FM Antenna (Smaller)
    All the above stuff i have purchased from ebay...
    _
    Mar 2004
    Little Elm, Texas
    This might do better off in the work logs forum?
    Mod?
    Jan Bennett
    Elsewhere
    Moved.
    How about the Wiki?
  1. Highlander Carputer Factory Install
    By qckfrze in forum General MP3Car Discussion
    Last Post: 09-18-2009, 10:48 PM
  2. BMW X5 Carputer Vinzer's project.
    By vinzer in forum Show off your project
    Last Post: 09-19-2008, 03:03 PM
  3. Carputer Class Project
    By discraftpro in forum Newbie
    Last Post: 01-26-2006, 12:52 PM
  4. Peugeot 206 GLX - LinITX 8" & Dell Laptop
    By Engram in forum Show off your project
    Last Post: 12-18-2005, 06:25 AM
  5. 98 Mustang Laptop Carputer install set to begin
    By comp98 in forum General MP3Car Discussion
    Last Post: 05-06-2005, 09:00 AM
